> 76 2.0l FI stock engine bucks under 2000 rpm and load
jdlmodelt
post May 8 2013, 07:09 AM
James D. Lane
Hi guys,
My 76 2.0l stock Fuel Injected engine is bucking when I press on the throttle to accelerate when the engine is under 2000RPM. Above that the engine is smooth and strong but below that point when I step on the throttle going down the hiway, it either bucks, stutters and doesn't accerate or doesn't buck but doesn't accellerate either. It is backfiring a little more than ussual as well. It let out a couple of big bangs at the tail pipe yesterday when I was down shifting to a stop light at lower speeds. So, running super rich at lower RPM? I changed the timing last week to smooth out the low idle. I'm guessing that may be some of it?
BUT, I was wondering if the throttle possition sensor needs to be adjusted along with the timing? It seems like there is some kind of relationship in the lower RPMS amongst the ignition timing, the injector timing, the throttle position sensor and the anti-backfiring valve?
914itis
post May 8 2013, 07:31 AM
I would start with the tps, check points, dwell and vaccum advance at distributor.
I had an issue of the ame except that mine was at 3300. I rebuilt my dizzy and problem went away.
jdlmodelt
post May 24 2013, 08:36 PM
James D. Lane
QUOTE(914itis @ May 8 2013, 07:31 AM) *
Adjusted TPS, then cleaned points, then it wouldn't start at all. I had filed the points, sprayed them with brake cleaner, then used the air gun to blow the distributor body out real good. All with the distributor still installed in the engine. Well, I finally pulled the distributor out of the engine and pulled the injector points out of the distributor and found lots of crud that I had just blown down further when I cleaned the points. So, I cleaned everything really good. put a tiny film of lube on the shaft and put it all back in. This is the smoothest this engine has run! (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 9th June 2026 - 02:28 AM
