> Glitch
partwerks
post May 24 2013, 06:32 AM
On my conversion, the first thing I had found when it was done, that after 3 years of rubbing, the one bolt that mounts the intercooler had been left a bit too long, and had rubbed a spot on one of the wires on top of the engine, where the connector is. It had apparently controlled the fuel pump, and so I shortened the bolt and used some silicone caulking on the wire, and I thought that was the end of the story. I think it is a separate issue from these others??
I don't know if these other 3 are related to each other, or not?
Randomly, like maybe once a week, if you are driving down the Interstate, it may cut out for a second or two, and then just go on like normal.
Also, the idle speed is usually about 1,000 but sometimes it will only idle about 500 rpm.
This last one, it had not done it for about 2 months, but I went into the store and came back out, and it would not start, till I waited about 8 minutes, and then it started right up.
Any thoughts, ideas or suggestions on what it could be, or if all 3 are related to something?
partwerks
post May 27 2013, 04:57 PM
According to the part number on the part, it must be a auto map sensor?
http://www.alibaba.com/product-gs/78710637...22627AA170.html
If I can get the part that snaps over it, would help eliminate, if that is the problem area?
- Lo-Fi Version Time is now: 9th June 2026 - 03:44 AM
