| lsintampa |
May 18 2013, 11:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0
Most drawings on fuel delivery that I can find show the fuel pump having three ports. Mine has only two ports (inflow and outflow). Gas tank and motor are currently OUT of the car. Looking in the front trunk, there are two fuel lines running to the engine bay. Outbound and inbound. Which of those two are sending fuel to the motor and which one is the return? Same question on the tank itself. There is a skinny sock filter on the inside of the tank, I'm guessing that is the line sending fuel out of the tank to the motor, correct? Thanks, Len |
| lsintampa |
May 28 2013, 06:56 AM
I think I have it....
I'm picking up my tank today - just got it resealed / painted, etc. Where does the small 5mm vent line terminate in the engine bay? To the canister filter - I assume. Also, has anyone run high pressure fuel lines through the tunnel? My 74 BMW 2002 had high pressure lines running along the inside of the cabin along the sills and up through the firewall. Thanks! |
| ThePaintedMan |
May 28 2013, 08:21 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
I think I have it.... I'm picking up my tank today - just got it resealed / painted, etc. Where does the small 5mm vent line terminate in the engine bay? To the canister filter - I assume. Also, has anyone run high pressure fuel lines through the tunnel? My 74 BMW 2002 had high pressure lines running along the inside of the cabin along the sills and up through the firewall. Thanks! Hey Len, I don't know about the vent line, as we talked about yesterday. But I'm not sure what you mean about the high pressure lines through the tunnel. Currently, that's how the car is setup - with the lines running through the tunnel. Yours are still the plastic ones, which I think we talked about replacing with stainless. Either way, running them through the cabin is probably not a good idea and I'm surprised BMW got away with it! (IMG:style_emoticons/default/biggrin.gif) |
lsintampa Fuel Delivery May 18 2013, 11:24 AM
JamesM 75-76 2 port pump in the front trunk was stock. Th... May 18 2013, 12:16 PM
914itis Have Fun! May 18 2013, 12:23 PM
r_towle starting at the tank.
Line with the sock is the s... May 18 2013, 01:31 PM
lsintampa
I'm picking up my ta... May 28 2013, 08:35 AM
Dave_Darling
Where does the small 5mm vent line terminate in t... May 28 2013, 02:48 PM
lsintampa Ordered new SS lines today...
Pulled out the old ... May 28 2013, 02:55 PM
ThePaintedMan Len,
Although getting the lines out was a bear,... May 28 2013, 05:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:07 AM |
