| JamesM |
May 28 2013, 05:04 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have never really documented the work I do on my cars, but figure this might be a good place to start as I have not seen too many people out there running these Rebel Racing Bushings.
Start with a little back story: A long time ago, in a state far far away... or at least as far left as you can go on the map. 13 or so years ago, before I did much work on my own cars I had some failing front bushings replaced with poly ones by a local alignment shot. They were ok aside from squeaking all the time, but then I really didn't push my car to the limit on a regular basis back then. Fast forward to today, been autocrossing for 5 or so years, always felt like the car has pushed really bad in the tighter stuff and always seems to lose traction in the front WAY to easy under breaking. Came to the conclusion that a lot of it is probably the poly bushings in the front sucking major @$$ and binding all the time. I had not planned on doing this upgrade this year but a failed rear bushing meant I had to get an alignment anyways so I figured might as well just do them all. Decided to go with the Rebel front setup as I like the design and don't like having to lube bushings all the time. Crapy phone pics to come... |
| 914_teener |
May 28 2013, 09:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
JamesM Rebel Bushing Install May 28 2013, 05:04 PM
JamesM Snag #1:
Never fun to have a sway bar mounting tab... May 28 2013, 05:15 PM
JamesM *sigh* really? This is how ONE of the control arms... May 28 2013, 05:26 PM
SirAndy *sigh* really?
:sick: May 28 2013, 05:29 PM
JamesM The poly bushings dont soften under heat like rubb... May 28 2013, 05:31 PM
JamesM So, this was just going to be a quick job of swapp... May 28 2013, 05:43 PM
JamesM Before and After
Races installed
May 28 2013, 05:46 PM
JamesM Purdy!
Install was quite a bit easier then d... May 28 2013, 05:56 PM
JamesM Should be able to finish getting everything back t... May 28 2013, 06:08 PM
914_teener
Should be able to finish getting everything back ... May 28 2013, 06:33 PM
JamesM
Should be able to finish getting everything back... May 28 2013, 07:30 PM
914_teener
[quote name='914_teener' post='1871100' date='May... May 28 2013, 09:39 PM
JamesM
[quote name='JamesM' post='1871130' date='May 28 ... May 29 2013, 12:19 AM
Jeff Hail
The poly bushings dont soften under heat like rub... May 28 2013, 06:46 PM
JamesM
The poly bushings dont soften under heat like ru... May 28 2013, 07:10 PM
JamesM Anyone else notice the crack in this picture? I h... May 29 2013, 12:48 AM
JamesM As the crack has been there for quite a while I am... May 29 2013, 01:04 AM
Jeff Hail
As the crack has been there for quite a while I a... May 29 2013, 07:08 AM
Eric_Shea Looking good James. :trophy: May 28 2013, 08:18 PM
jmill :cheer:
Rebel has some cool stuff. May 28 2013, 08:53 PM
Jeff Hail Put a large flat washer on both sides with a large... May 28 2013, 10:37 PM
Jeff Hail Funny.. I just noticed this under the banner.
... May 28 2013, 10:43 PM
SirAndy Funny.. I just noticed this under the banner.
... May 29 2013, 11:31 AM
76-914 At least "stop drill" that crack. May 29 2013, 08:11 AM
Eric_Shea
Pretty much spot on James. Jeff, these bushings... May 29 2013, 09:20 AM
Jeff Hail
Pretty much spot on James. Jeff, these bushing... May 30 2013, 07:33 AM
Eric_Shea RE: Crack - Call Troy and get it in. I think he h... May 29 2013, 09:36 AM
JamesM
RE: Crack - Call Troy and get it in. I think he ... May 29 2013, 10:06 AM
JamesM Haven't hooked the sway bar back up yet or got... May 29 2013, 10:30 AM
914_teener Thanks for the info James...and Eric. I didn... May 29 2013, 01:32 PM
JamesM
Thanks for the info James...and Eric. I didn... May 29 2013, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 03:53 AM |
