Rebel Bushing Install, also yet another reason I dont let "pro" shops touch my cars |
JamesM |
May 28 2013, 05:04 PM
Senior Member Group: Members Posts: 1,916 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have never really documented the work I do on my cars, but figure this might be a good place to start as I have not seen too many people out there running these Rebel Racing Bushings.
Start with a little back story: A long time ago, in a state far far away... or at least as far left as you can go on the map. 13 or so years ago, before I did much work on my own cars I had some failing front bushings replaced with poly ones by a local alignment shot. They were ok aside from squeaking all the time, but then I really didn't push my car to the limit on a regular basis back then. Fast forward to today, been autocrossing for 5 or so years, always felt like the car has pushed really bad in the tighter stuff and always seems to lose traction in the front WAY to easy under breaking. Came to the conclusion that a lot of it is probably the poly bushings in the front sucking major @$$ and binding all the time. I had not planned on doing this upgrade this year but a failed rear bushing meant I had to get an alignment anyways so I figured might as well just do them all. Decided to go with the Rebel front setup as I like the design and don't like having to lube bushings all the time. Crapy phone pics to come... |
914_teener |
May 29 2013, 01:32 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Thanks for the info James...and Eric. I didn't know there was a thread on these?
Will do on the rears as suggested. I am hoping for at least three years play with these hard durometer bushings at least. Just a question on the fronts that you used James....how does the road noise and vibration stack up on the street in your opinion?. I know this is subjective since you ax your car apparently. Thanks for the thread. |
JamesM |
May 29 2013, 03:38 PM
Thanks for the info James...and Eric. I didn't know there was a thread on these? Will do on the rears as suggested. I am hoping for at least three years play with these hard durometer bushings at least. Just a question on the fronts that you used James....how does the road noise and vibration stack up on the street in your opinion?. I know this is subjective since you ax your car apparently. Thanks for the thread. I would suspect you would get a lot longer then 3 years out of the rears if they are installed properly, and re-lubed on a semi regular basis. As for how they stack up on the street, keep in mind I have only driven of them for about 10 minutes at this point, but compared to the polys its a HUGE difference. I had for the most part stopped driving this car on the street when I moved to Utah due to it just being to rough and noisy (didnt bother me on califormia freeways as they were a lot smoother) With the new setup being so fluid its allowing the suspension to absorb the bumps rather then transmit them through the chasis (or just ripping the chasis apart) so despite being 100% solid bushings they give a suprising smooth ride. Ill give an update after i get the car alligned and get more time on them, but right now I am thinking I am going to start driving it on the street more. This is on a car running no carpet, no sound pads, and 215/45-16s with very stiff sidewalls at 37PSI cold. To add a little more perspective, I had had a rattle comming from behind my head for quite a while (either the window seal or possibly the engine lid) I didnt really pay to much attention to it before as the entire car was resonating sound. On my short test drive all i could think of was how I wanted to fix that rattle as it was the only thing I was picking up on other then the sound of the engine. I would guess that on a stock car the ride would be not at all unplesant. I still need to hook up the sway bar again, but with just bilstiens and turbo tie rods the front end feels razor sharp. |
Lo-Fi Version | Time is now: 12th June 2024 - 06:32 AM |
