| tornik550 |
May 27 2013, 08:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am trying to get my engine tuned. The engine is running well however due to a bad spark plug wire I flooded a cylinder which in turn killed an O2 sensor. I have since got my engine running well and my air fuel gauge had been working well with a new o2 sensor. Now I am getting bad o2 sensor error codes again. Not sure why- it has only been a few weeks. My engine is running very well however a little too rich. Head and oil temps are perfect. I use an innovate lc1 and gauge.
I read about using a bung extender. There is one listed on innovate's website for around $90. There are cheap looking ones on ebay for about $0.90. I don't mind ordering the innovate one if that is what I need however 1/100 of the price for the cheap ones would be nice also- if that would work. Any ideas? |
| mrbubblehead |
May 29 2013, 09:07 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i may have my old one. i dont think i thru it out. its not pretty, but it works if you want it. i potted it in liquid tape so there is nothing exposed except the little dial for adjusting the timer. it takes a real small jewelers screwdriver to adjust it. but you may not even have to mess with the timer.
tornik550 I keep killing O2 sensors- Innovate LC1 May 27 2013, 08:02 PM
McMark Where is it installed? May 27 2013, 08:07 PM
tornik550
I have triad headers. I... May 27 2013, 08:10 PM
brant any chance you could have a power or ground proble... May 27 2013, 08:47 PM
tornik550
any chance you could have a power or ground probl... May 27 2013, 09:01 PM
mrbubblehead mine would show an error code right after start up... May 27 2013, 08:58 PM
rhodyguy triad muffler with the 3 resonators? May 27 2013, 09:26 PM
tornik550
Triad head... May 28 2013, 05:07 AM
rhodyguy i don't think the triad muffler lends itself t... May 28 2013, 07:55 AM
tornik550
i don't think the triad muffler lends itself ... May 28 2013, 08:16 AM
stugray
I know the wiring by memory as I was just instal... May 28 2013, 08:47 AM
tornik550 So I went through and made sure that my wiring is ... May 28 2013, 07:43 PM
mrbubblehead
So I went through and made sure that my wiring is... May 28 2013, 08:21 PM
tornik550
So I went through and made sure that my wiring i... May 28 2013, 08:23 PM
mrbubblehead no. its not specifically for the lc1. mine was ran... May 28 2013, 08:28 PM
tornik550 So am I understanding this correctly- if I put a s... May 28 2013, 08:33 PM
mrbubblehead EXACTLY! and if it works i will give you the d... May 28 2013, 08:43 PM
tornik550
EXACTLY! and if it works i will give you the ... May 29 2013, 06:51 PM
mrbubblehead
EXACTLY! and if it works i will give you the... May 29 2013, 07:54 PM
mrbubblehead here it is....
http://www.914world.com/bbs2/upload... May 29 2013, 08:01 PM
tornik550
here it is....
[url=http://s722.photobucket.com/u... May 29 2013, 08:59 PM
mrbubblehead its actually not to bad if you use a piece of brea... May 29 2013, 09:02 PM
tornik550 I think I am going to get all the supplies over th... May 29 2013, 09:05 PM
mrbubblehead
I think I am going to get all the supplies over t... May 29 2013, 09:10 PM
tornik550
i may have my old one. i dont think i thru it out... May 29 2013, 09:17 PM
mrbubblehead
i may have my old one. i dont think i thru it ou... May 29 2013, 09:21 PM
stugray Just be careful that you do not wait too long or f... May 29 2013, 09:18 PM
mrbubblehead
Just be careful that you do not wait too long or ... May 29 2013, 09:28 PM
mrbubblehead I FOUND THE TIMER!!!! :Qarl: and i... May 30 2013, 07:25 PM
michael7810 Has anyone tried the heatsink? My first O2 sensor... Jun 11 2013, 07:22 PM
tornik550
Has anyone tried the heatsink? My first O2 senso... Jun 11 2013, 08:28 PM
kg6dxn
Has anyone tried the heatsink? My first O2 senso... Jun 11 2013, 08:48 PM
mrbubblehead i tried the heat sink first. and it seemed to work... Jun 11 2013, 08:51 PM
Harpo Where did you get your heat sink?
Thanks
David Jun 20 2013, 04:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:39 PM |
