> I keep killing O2 sensors- Innovate LC1, Would a bung extender help?
tornik550
post May 27 2013, 08:02 PM
I am trying to get my engine tuned. The engine is running well however due to a bad spark plug wire I flooded a cylinder which in turn killed an O2 sensor. I have since got my engine running well and my air fuel gauge had been working well with a new o2 sensor. Now I am getting bad o2 sensor error codes again. Not sure why- it has only been a few weeks. My engine is running very well however a little too rich. Head and oil temps are perfect. I use an innovate lc1 and gauge.
I read about using a bung extender. There is one listed on innovate's website for around $90. There are cheap looking ones on ebay for about $0.90. I don't mind ordering the innovate one if that is what I need however 1/100 of the price for the cheap ones would be nice also- if that would work.
Any ideas?
stugray
post May 29 2013, 09:18 PM
Just be careful that you do not wait too long or forget to turn the LC-1 on after the car starts. The LC-1 instructions say to never run the engine without the LC-1 powered or it can damage the sensor.
And they make time delay relays that are adjustable.
I have some, but they work at 28V. I'll see if they still operate at 12VDC...
Stu
tornik550   I keep killing O2 sensors- Innovate LC1   May 27 2013, 08:02 PM
McMark   Where is it installed?   May 27 2013, 08:07 PM
tornik550   Where is it installed? I have triad headers. I...   May 27 2013, 08:10 PM
brant   any chance you could have a power or ground proble...   May 27 2013, 08:47 PM
tornik550   any chance you could have a power or ground probl...   May 27 2013, 09:01 PM
mrbubblehead   mine would show an error code right after start up...   May 27 2013, 08:58 PM
rhodyguy   triad muffler with the 3 resonators?   May 27 2013, 09:26 PM
tornik550   triad muffler with the 3 resonators? Triad head...   May 28 2013, 05:07 AM
rhodyguy   i don't think the triad muffler lends itself t...   May 28 2013, 07:55 AM
tornik550   i don't think the triad muffler lends itself ...   May 28 2013, 08:16 AM
stugray   I know the wiring by memory as I was just instal...   May 28 2013, 08:47 AM
tornik550   So I went through and made sure that my wiring is ...   May 28 2013, 07:43 PM
mrbubblehead   So I went through and made sure that my wiring is...   May 28 2013, 08:21 PM
tornik550   So I went through and made sure that my wiring i...   May 28 2013, 08:23 PM
mrbubblehead   no. its not specifically for the lc1. mine was ran...   May 28 2013, 08:28 PM
tornik550   So am I understanding this correctly- if I put a s...   May 28 2013, 08:33 PM
mrbubblehead   EXACTLY! and if it works i will give you the d...   May 28 2013, 08:43 PM
tornik550   EXACTLY! and if it works i will give you the ...   May 29 2013, 06:51 PM
mrbubblehead   EXACTLY! and if it works i will give you the...   May 29 2013, 07:54 PM
mrbubblehead   here it is.... http://www.914world.com/bbs2/upload...   May 29 2013, 08:01 PM
tornik550   here it is.... [url=http://s722.photobucket.com/u...   May 29 2013, 08:59 PM
mrbubblehead   its actually not to bad if you use a piece of brea...   May 29 2013, 09:02 PM
tornik550   I think I am going to get all the supplies over th...   May 29 2013, 09:05 PM
mrbubblehead   I think I am going to get all the supplies over t...   May 29 2013, 09:10 PM
mrbubblehead   i may have my old one. i dont think i thru it out....   May 29 2013, 09:07 PM
tornik550   i may have my old one. i dont think i thru it out...   May 29 2013, 09:17 PM
mrbubblehead   i may have my old one. i dont think i thru it ou...   May 29 2013, 09:21 PM
stugray   Just be careful that you do not wait too long or f...   May 29 2013, 09:18 PM
mrbubblehead   Just be careful that you do not wait too long or ...   May 29 2013, 09:28 PM
mrbubblehead   I FOUND THE TIMER!!!! :Qarl: and i...   May 30 2013, 07:25 PM
michael7810   Has anyone tried the heatsink? My first O2 sensor...   Jun 11 2013, 07:22 PM
tornik550   Has anyone tried the heatsink? My first O2 senso...   Jun 11 2013, 08:28 PM
kg6dxn   Has anyone tried the heatsink? My first O2 senso...   Jun 11 2013, 08:48 PM
mrbubblehead   i tried the heat sink first. and it seemed to work...   Jun 11 2013, 08:51 PM
Harpo   Where did you get your heat sink? Thanks David   Jun 20 2013, 04:57 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:13 PM
