> Anyone ever use the stock alternator without the relay board?, Racers?
stugray
post May 31 2013, 07:59 PM
I am guessing that someone else has tried this.
I have a stock alternator in my race car for now (upgrading to new 1-wire later). Relay board and entire harness is gone.
I know that I need the external voltage regulator, so I decided I better figure out how to wire it up...
It turns out that the plug from the Alt that goes to the relay board is exactly the same connector & pinout of the Voltage Regulator!
So it can just plug right in... not so fast.
For the alternator to startup/charge, it needs the voltage that is fed from the Alt light in the combo gauge.
SO, can I just wire in a bulb from +12V and splice it into the D+ lead on that connector where it goes into the VR plug?
Then the system should work exactly as before....??
Is the stock Alt bulb a special wattage?
Stu
stugray
post May 31 2013, 08:58 PM
Thanks for the responses so quick!
i use super brite LEDS for my idiot lights so i did have to wire a little incandescent bulb for the alternator. the led didnt pull enuff load by itself.
That is funny! I didnt want to complicate the question by asking: Ok, now, can I use a 12V LED instead of the stock idiot light ;-)
How did you determine it would not work?
I figured if it didnt work, I would just add a resistor across the LED to give it more current.
Anyone know how much current the Alt field winding needs to work?
Stu
- Lo-Fi Version Time is now: 6th July 2025 - 11:33 AM
