914boy |
Newbie ![]() Group: Members Posts: 11 Joined: 2-June 13 From: NYC Member No.: 15,956 Region Association: North East States ![]() |
The car was carbs and the fuel pump was on constant when the key is on.
I am trying to put it back to factory settings. As far as I understand in djets, when the key is turned on, there is a pulse to turn the pump on for a quick second then once the car starts the ecu keeps the power on to keep the fuel pump running. I am not getting that pulse. The relay clicks and I even switched the relay. I noticed that the PO modified the connectors on the relay board for the carbs. (See pics) please help me she's some lights The car is a 1.7 djet year 1970 Thanks Attached thumbnail(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Remember that the wiring can differ slightly from year to year. For instance, my 74 has a green wire looping from one pin of the 12-pin connector to another.
Here's the 71 relay board, the 71 should be identical: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-121-1370298770.1.jpg) Compare the colors in the connections to what you have. It looks like you may be missing a couple of relays on the board? You need the middle two to run the pump; one of them powers the FI and the other powers the pump. The pump will not run unless the FI tells it to, BTW. --DD |
Lo-Fi Version | Time is now: 7th July 2025 - 10:34 AM |
