> My first garage thread / fuel pump, Relay board modification.
914boy
post Jun 3 2013, 07:32 AM
The car was carbs and the fuel pump was on constant when the key is on.
I am trying to put it back to factory settings.
As far as I understand in djets, when the key is turned on, there is a pulse to turn the pump on for a quick second then once the car starts the ecu keeps the power on to keep the fuel pump running.
I am not getting that pulse. The relay clicks and I even switched the relay.
I noticed that the PO modified the connectors on the relay board for the carbs.
(See pics) please help me she's some lights
The car is a 1.7 djet year 1970
Thanks
914itis
post Jun 4 2013, 06:07 AM
Yes the III was grounded, in addition pin # 10 on the 12 pin connector (yellow-green) is jumped to the fuel pump wire ( pin 13 of 14 pin connector b/r)
We understand the reason for the ground as Mark pointed out on carbs for constant on, but don't understand the reason for the jumped wire.
We will put the full system together and troubleshoot from there.
- Lo-Fi Version Time is now: 7th July 2025 - 10:23 AM
