Brain check - valve adjustment |
ThePaintedMan |
Jun 4 2013, 05:18 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Okay, so I just need a logic/brain check here. I've been doing valve adjustments the Cap'ns way since I got the car, but Rich suggested I try a go/no go method to see if I can figure out what is causing my backfiring problem.
Basically, I need to get one valve open as far as possible, making sure that the OPPOSITE valve is as closed as possible. In this case, #1 exhaust and # 3 exhaust. So if I'm looking at #1 exhaust and it is open (the rocker has play in it) then the #3 exhaust should be closed solid, correct? Rich, sorry to post this for all to see, I'm just looking for an answer quickly so I can get this buttoned back up before it's dark. Thanks for your help! |
Dave_Darling |
Jun 4 2013, 08:53 PM
There are four lobes on the camshaft. The forward pair of cylinders share two cam lobes (one intake, one exhaust) and the rear pair share the other pair of cam lobes. Intake and exhaust are offset from each other, but the intake lobes of the front cylinders are guaranteed to be 180 degrees apart from each other.
--DD |
Lo-Fi Version | Time is now: 12th June 2024 - 07:40 PM |
