> Modern Programable T4 ITB Injection, Megasquirt and Bolt-On Trigger Wheel
DBCooper
post Jun 7 2013, 08:00 AM
14's in the 13's with ATTITUDE
From Mario at thedubshop.net:
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-b-a.akamaihd.net-2618-1370613617.1.jpg)
And:
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-2618-1370613619.2.jpg)
And CB ITB's:
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-2618-1370613619.3.jpg)
He's done some good work for my son's turbo-Subaru bug. I don't know cost or anything, just noticed those while looking for some other things.
MarioVelotta
post Jun 7 2013, 11:59 PM
QUOTE(McMark @ Jun 7 2013, 08:04 PM) *
Microsquirt doesn't have a built in MAP sensor. But I'd wager on an external MAP sensor. It's the easiest to set up. I wouldn't be surprised if there is a TPS involved, but usually it's pretty much ignored unless you have a wild cam at idle.
That is also correct, the Microsquirt does not carry an internal MAP like it's big brother. Another reason the MS2 V3 is my goto.
I disagree on the external MAP being easier to set up. It adds wiring, and if you want barometric correction for spirited mountain driving you need 2. Adding more wiring. On the V3 board you just add the MapDaddy sensor and call it a day. Using the same singe vacuum line that is going to the ECU.
TPS isn't necessary with Speed Density fueling using a map sensor, but it sure helps with acceleration enrichment. I've always had a hard time getting reliable acceleration enrichment's just using engine vacuum variation. Not that is can't be done...
TPS data in a log is invaluable IMHO, it really tells you what the driver is trying to accomplish during the drive.
DBCooper   Modern Programable T4 ITB Injection   Jun 7 2013, 08:00 AM
rhodyguy   my guess is painfully expensive.   Jun 7 2013, 08:11 AM
nathansnathan   From Mario at thedubshop.net: [img]http://www.91...   Jun 7 2013, 08:24 AM
worn   http://www.914world.com/bbs2/uploads_offsite/image...   Jun 7 2013, 12:56 PM
ThePaintedMan   VW Bus engine bay. Source: grew up sticking my...   Jun 7 2013, 01:08 PM
nathansnathan   http://www.914world.com/bbs2/uploads_offsite/imag...   Jun 7 2013, 02:07 PM
wndsrfr   Did a wideband A/FR come with the kit also or do y...   Jun 7 2013, 08:30 AM
r_towle   get him on this forum...get him hearing the Type4 ...   Jun 7 2013, 08:50 AM
Mark Henry   get him on this forum...get him hearing the Type4...   Jun 7 2013, 09:18 AM
nathansnathan   The bolt pattern is definitely for the fan, to fit...   Jun 7 2013, 09:23 AM
ThePaintedMan   Those intakes and throttle bodies are CB Performan...   Jun 7 2013, 09:40 AM
McMark   He has for a couple years. Only with a trigger s...   Jun 7 2013, 11:10 AM
nathansnathan   He has for a couple years. Only with a trigger ...   Jun 7 2013, 11:16 AM
Matt Romanowski   With sensors from GERMAN cars so they look right...   Jun 7 2013, 08:26 PM
McMark   [quote name='McMark' post='1876313' date='Jun 7 2...   Jun 7 2013, 09:01 PM
DBCooper   [quote name='Matt Romanowski' post='1876572' date...   Jun 7 2013, 09:55 PM
Jeff Hail   With sensors from GERMAN cars so they look righ...   Aug 30 2013, 09:29 PM
Bob L.   [quote name='Matt Romanowski' post='1876572' date...   Aug 30 2013, 11:14 PM
McMark   :rolleyes:   Jun 7 2013, 11:27 AM
nathansnathan   It's all good. I needed a 36-1 wheel and some ...   Jun 7 2013, 11:38 AM
DNHunt   It's hard for me to tell but, if that bracket ...   Jun 7 2013, 01:11 PM
DBCooper   Somebody said he's in Great Britain, no. Ther...   Jun 7 2013, 02:11 PM
r_towle   Micro, mega, macro squirts......how is air measure...   Jun 7 2013, 06:30 PM
DBCooper   You'll have to ask him about that. MAP is bui...   Jun 7 2013, 07:25 PM
McMark   You'll have to ask him about that. MAP is bu...   Jun 7 2013, 09:04 PM
MarioVelotta   Hey guys, guess I'll chime in :D I've o...   Jun 7 2013, 09:44 PM
nathansnathan   To answer some questions on the T4 trigger wheel...   Jun 8 2013, 02:48 AM
DBCooper   Thanks for dropping by, Mario. Parts are getting ...   Jun 7 2013, 10:10 PM
RonW   Not that I have many posts on here but thought I...   Jun 7 2013, 10:20 PM
aircooledtechguy   Mario; Thanks for coming over to the dark side. ...   Jun 7 2013, 10:24 PM
MarioVelotta   Microsquirt doesn't have a built in MAP sensor...   Jun 7 2013, 11:59 PM
McMark   Its easiest to set up meaning MAP vs. AlphaN vs. M...   Jun 8 2013, 12:06 AM
jd74914   Its easiest to set up meaning MAP vs. AlphaN vs. ...   Jun 8 2013, 07:28 AM
MarioVelotta   So here is a kit I just got done with that you guy...   Jun 19 2013, 12:02 PM
monkeyboy   What does a kit like that cost? I'd like to se...   Jun 19 2013, 02:00 PM
MarioVelotta   My ITB kits start at $2500 without ignition c...   Jun 19 2013, 02:35 PM
monkeyboy   Thanks.   Jun 19 2013, 02:41 PM
rwilner   Check out the microsquirt install in my signature....   Jun 19 2013, 07:48 PM
MarioVelotta   Cool! I do a Microsquirt based plug and play ...   Jun 19 2013, 08:17 PM
worn   Cool! I do a Microsquirt based plug and play...   Jun 20 2013, 05:30 PM
McMark   Not sure where you got that. I've sold three...   Jun 19 2013, 11:49 PM
MarioVelotta   Not sure where you got that. I've sold thre...   Jun 20 2013, 12:02 AM
rwilner   Not sure where you got that. I've sold thr...   Jun 20 2013, 05:15 PM
monkeyboy   McMark, do you have an available kit for ITB's...   Jun 20 2013, 12:06 PM
McMark   Sure. Just have to change a few wire lengths on t...   Jun 20 2013, 01:54 PM
Mark Henry   Sure. Just have to change a few wire lengths on ...   Jun 20 2013, 01:59 PM
monkeyboy   Possibly, but my long term goal is to continue usi...   Jun 20 2013, 02:01 PM
Mark Henry   Ok.... but stock TB plenum and runners can be had ...   Jun 20 2013, 02:06 PM
monkeyboy   I'm not worried too much about cheap. I alread...   Jun 20 2013, 03:39 PM
MarioVelotta   I am glad you have something to offer in this a...   Jun 20 2013, 05:46 PM
DBCooper   There seems to be a feeling that some toes are bei...   Jun 20 2013, 08:24 PM
worn   There seems to be a feeling that some toes are be...   Jun 20 2013, 09:45 PM
McMark   Absolutely! Just trying to make sure my offer...   Jun 20 2013, 09:46 PM
rick 918-S   Great to see we have two guys with great knowledge...   Jun 20 2013, 09:55 PM
McMark   No, you're right Rick. It is VooDoo!   Jun 20 2013, 10:41 PM
rick 918-S   No, you're right Rick. It is VooDoo! ...   Jun 20 2013, 11:27 PM
MarioVelotta   Another Dual TB kit. This particular one if for a ...   Jun 26 2013, 01:31 AM
rdauenhauer   Very nice. :headbanger: Ill be visiting soon.   Jun 26 2013, 02:21 PM
McMark   That's cool. Love the rapid prototyping. :wu...   Jun 26 2013, 03:16 PM
MarioVelotta   Well these rails got made, and are a great success...   Aug 29 2013, 01:22 PM
MarioVelotta   My new project is a Mini Cam Sync for sequential f...   Aug 29 2013, 01:32 PM
DBCooper   Yeah, quick question Mario: what in the f*** are ...   Aug 29 2013, 02:44 PM
MarioVelotta   :DRUNK: :D   Aug 29 2013, 04:03 PM
ConeDodger   If the buyer of my motor is wise, he'll have M...   Aug 29 2013, 04:20 PM
Racer Chris   ... eliminate the SDS and go to Megasquirt. The ...   Aug 29 2013, 06:18 PM
DBCooper   Yeah, the flip side of the "simple" in S...   Aug 29 2013, 05:59 PM
aircooledtechguy   Here's Mario doing that voodoo that he,. . . d...   Aug 29 2013, 09:15 PM
- Lo-Fi Version Time is now: 1st November 2026 - 07:51 PM
