> Locked Up!, What might it be?
74914LE
post Jun 8 2013, 04:21 PM
Just finished getting a 72 1.7ltr. ready to start up after sitting for 29 years. Went over everything in the fuel, vacuum, and ignition systems. It turned over just fine without spark hooked up to it. Now for the moment of truth. Made sure I had fuel pressure and attempted to start it.
After about 3 tries, it fired up and started running!!!! After about 20 seconds, a rattling sound started, then got worse. I immediately shut it off. Then tried to turn it over again, and it would not turn over. I then got it on jack stands and blocked one wheel to put it in gear and see if I could spin the motor by hand with
transmission in 5th gear. The wheel will turn about 1/3 a turn in either direction and it locks.
Before I drop the motor and pull it apart to check for a dropped valve or worse, though I would see if anyone wanted to weigh in on what this might be....ideas?
Thanks in advance!
TheCabinetmaker
post Jun 8 2013, 07:57 PM
I drive my car everyday
Like suggested, pull the valve covers and check for an open valve with lots of rocker play.
- Lo-Fi Version Time is now: 1st August 2025 - 02:41 PM
