> Recomendations for the cleaning of electrical connections
Harpo
post Jun 9 2013, 12:36 PM
For the record I did use the search option and was unsuccessful searching
What can I use to clean up my terminals for the electrical connections in my 914? Somewhere I had read something about dielectric grease but I'm thinking I need to clean the terminals first.
Thanks for your help
David
pcar916
post Jun 9 2013, 01:15 PM
Is that a Lola?
I've used these for 40 years.
http://www.stanleysupplyservices.com/jonar...rnishers/g/8172
Still have the original one. Mine has diamond strips with different grits and came with ~10 strips in the handle.. Once you've cleaned chemically, then with bronze and SS brushes, then start polishing with this. Polish is a way to reduce surface area (against oxygen) and is a corrosion fighting system as well.
Not the harsh file-oriented cleanup but this is where you build in further problems, assuming you're not pushing too much current through the connector.
Good luck
- Lo-Fi Version Time is now: 15th March 2026 - 02:42 PM
