> Dellorto problem. disaster averted, garage reeks of fuel
rhodyguy
post Jun 9 2013, 04:25 PM
all set, ready for fire up, energize the pump (didn't spin the engine) and the pump doesn't quiet down (cb carb pump) as the bowls fill as it did with the webers. i look over and there's a thin fountain the coming up and fuel welling thru the square in between the main stacks on the dr side carb. puddles on top of both of the throttle plates.
the pass side has the duel banjo fitting. fuel supply line connects to one fitting and the other fitting is supposed to supply the dr side eliminating the need for a 'T". does it make any dif which fitting gets the pump supply and which one connects to the dr side carb? top fitting as opposed to bottom. the dellorto book mentions the dual banjo but doesn't specify if it makes a dif where the lines are/how hooked up.
i had just changed out the oil so i know the 3 1/2 quarts of BP will get dumped. any ideas?
k
nathansnathan
post Jun 9 2013, 05:22 PM
I had this same thing happening after about a year running carbs that had been rebuilt by Gabriel off ebay on my drla 40s. It ended up being a "heavy float". You could see the outside of the float had been compromised and it was absorbing fuel.
I also noted some stiction in the springs in the plungers of the needle valves. Though Gabriel's worn out bits were worlds better than what you may find in a cb performance rebuild kit, you can get the real deal, a viton-tipped dellorto oem INC needle valve from Dellorto uk along with a new float or 2.
Don't listen to the people who want to talk about their 'Dellorto drip'. That is in every thread about Dellorto problems, someone saying, "yep, the Dellorto drip...".
(IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/smile.gif)
rhodyguy   Dellorto problem. disaster averted   Jun 9 2013, 04:25 PM
FourBlades   This happened to me twice when my float valves wou...   Jun 9 2013, 04:38 PM
rhodyguy   i was lucky not to have tried to start it. this wa...   Jun 9 2013, 04:50 PM
DBCooper   does it make any dif which fitting gets the pump s...   Jun 9 2013, 05:19 PM
nathansnathan   I had this same thing happening after about a year...   Jun 9 2013, 05:22 PM
rhodyguy   took the top off. big goober of debris was lying o...   Jun 9 2013, 05:41 PM
rhodyguy   while i'm under there...turn the key to the fi...   Jun 9 2013, 05:50 PM
rhodyguy   plugs out and it turns over nicely. briefly, all i...   Jun 9 2013, 06:04 PM
rhodyguy   a portion of the crap that was in the bowl. was ab...   Jun 9 2013, 06:11 PM
sixnotfour   Carb Stone, It wont pass though..   Jun 9 2013, 06:29 PM
rhodyguy   seriously? if the coil had been hooked up and the ...   Jun 9 2013, 07:04 PM
ThePaintedMan   If it was completely hydrolocked, it wouldn't ...   Jun 9 2013, 07:55 PM
nathansnathan   Hydrolock will definitely happen, cylinder is fill...   Jun 9 2013, 08:09 PM
rhodyguy   nathan, thanks for the tip about dellorto uk. othe...   Jun 9 2013, 08:49 PM
DBCooper   You didn't mention the needle valves. You say...   Jun 10 2013, 06:14 AM
rick 918-S   Kev, You may know this already but when viewing ...   Jun 10 2013, 07:54 AM
rhodyguy   thanks rick. i checked the float/valve action when...   Jun 10 2013, 08:16 AM
FourBlades   The thing which caused my floats to hang up was th...   Jun 10 2013, 09:29 AM
- Lo-Fi Version Time is now: 11th July 2025 - 04:47 PM
