rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
all set, ready for fire up, energize the pump (didn't spin the engine) and the pump doesn't quiet down (cb carb pump) as the bowls fill as it did with the webers. i look over and there's a thin fountain the coming up and fuel welling thru the square in between the main stacks on the dr side carb. puddles on top of both of the throttle plates.
the pass side has the duel banjo fitting. fuel supply line connects to one fitting and the other fitting is supposed to supply the dr side eliminating the need for a 'T". does it make any dif which fitting gets the pump supply and which one connects to the dr side carb? top fitting as opposed to bottom. the dellorto book mentions the dual banjo but doesn't specify if it makes a dif where the lines are/how hooked up. i had just changed out the oil so i know the 3 1/2 quarts of BP will get dumped. any ideas? k |
rhodyguy |
thanks rick. i checked the float/valve action when i took the top off yest. the valve operates freely as does the float swing. no sign of the floats full of fuel. whether the float height is correct, is uncertain. when i reinstalled the float plate and powered the pump up the crisis was gone. thomlinson' del book is not as comprehensive as the weber one. at least to me. i'll be buttoning up yesterday's take apart in awhile, bolting the triad up, and we'll see how things go. i haven't been this excited about the 73' in a loooong time.
Lo-Fi Version | Time is now: 11th July 2025 - 04:58 PM |
