> Dellorto problem. disaster averted, garage reeks of fuel
rhodyguy
post Jun 9 2013, 04:25 PM
all set, ready for fire up, energize the pump (didn't spin the engine) and the pump doesn't quiet down (cb carb pump) as the bowls fill as it did with the webers. i look over and there's a thin fountain the coming up and fuel welling thru the square in between the main stacks on the dr side carb. puddles on top of both of the throttle plates.
the pass side has the duel banjo fitting. fuel supply line connects to one fitting and the other fitting is supposed to supply the dr side eliminating the need for a 'T". does it make any dif which fitting gets the pump supply and which one connects to the dr side carb? top fitting as opposed to bottom. the dellorto book mentions the dual banjo but doesn't specify if it makes a dif where the lines are/how hooked up.
i had just changed out the oil so i know the 3 1/2 quarts of BP will get dumped. any ideas?
k
FourBlades
post Jun 10 2013, 09:29 AM
From Wreck to Rockin
The thing which caused my floats to hang up was the 90 degree arm that goes down and controls the float range of motion. If the float arm got cocked up it was this lower arm that would get stuck and not let the float move up and close the needle valve.
I am sure this makes no sense unless you have taken a weber or dellorto apart.
I caused this problem when bending this lower arm to reset the open versus closed height of the float. Make sure your float can still move correctly after adjusting it.
BTW, these heights were wrong on 2 sets of carbs I got in the mail. The floats bounce a lot in shipping with no fuel to cushion them leading to them being out os spec. (I think McMark id-ed the cause of this problem). If the float levels are off then you run leaner or richer than you should and it makes tuning harder.
John
rhodyguy   Dellorto problem. disaster averted   Jun 9 2013, 04:25 PM
FourBlades   This happened to me twice when my float valves wou...   Jun 9 2013, 04:38 PM
rhodyguy   i was lucky not to have tried to start it. this wa...   Jun 9 2013, 04:50 PM
DBCooper   does it make any dif which fitting gets the pump s...   Jun 9 2013, 05:19 PM
nathansnathan   I had this same thing happening after about a year...   Jun 9 2013, 05:22 PM
rhodyguy   took the top off. big goober of debris was lying o...   Jun 9 2013, 05:41 PM
rhodyguy   while i'm under there...turn the key to the fi...   Jun 9 2013, 05:50 PM
rhodyguy   plugs out and it turns over nicely. briefly, all i...   Jun 9 2013, 06:04 PM
rhodyguy   a portion of the crap that was in the bowl. was ab...   Jun 9 2013, 06:11 PM
sixnotfour   Carb Stone, It wont pass though..   Jun 9 2013, 06:29 PM
rhodyguy   seriously? if the coil had been hooked up and the ...   Jun 9 2013, 07:04 PM
ThePaintedMan   If it was completely hydrolocked, it wouldn't ...   Jun 9 2013, 07:55 PM
nathansnathan   Hydrolock will definitely happen, cylinder is fill...   Jun 9 2013, 08:09 PM
rhodyguy   nathan, thanks for the tip about dellorto uk. othe...   Jun 9 2013, 08:49 PM
DBCooper   You didn't mention the needle valves. You say...   Jun 10 2013, 06:14 AM
rick 918-S   Kev, You may know this already but when viewing ...   Jun 10 2013, 07:54 AM
rhodyguy   thanks rick. i checked the float/valve action when...   Jun 10 2013, 08:16 AM
FourBlades   The thing which caused my floats to hang up was th...   Jun 10 2013, 09:29 AM
- Lo-Fi Version Time is now: 11th July 2025 - 04:48 PM
