> Making the type four rev higher
Trekkor
post Jun 10 2013, 04:55 PM
I do things...
I have a VW Bug race car with a type four motor.
I would like it to safely rev up to 6500-7000 rpms.
What is needed to accomplish this?
thanks
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-c-a.akamaihd.net-1413-1370904931.1.jpg)
KT
Trekkor
post Jun 11 2013, 11:41 PM
I do things...
That's probably my biggest complaint with the stock TIV motor, the low rpm redline.
Today's modern 4 cylinder sportscars rev to 6500 or higher.
My '99 Ford Escort does.
Also, I'm looking for a '69 VW Bug gear chart that shows speeds in each gear at the full rpm range.
KT
This post has been edited by Trekkor: Jun 11 2013, 11:45 PM
Trekkor   Making the type four rev higher   Jun 10 2013, 04:55 PM
ConeDodger   Extreme balance. Light driveline components. Ignor...   Jun 10 2013, 05:00 PM
timothy_nd28   heavy duty valve springs and chrome moly pushrods   Jun 10 2013, 05:02 PM
The Cabinetmaker   My 2056 has the raby valve train kit with stock sp...   Jun 10 2013, 05:13 PM
DBCooper   All kinds of drag racers spinning them faster than...   Jun 10 2013, 05:19 PM
ConeDodger   All kinds of drag racers spinning them faster tha...   Jun 10 2013, 05:27 PM
WLD419   Some might say the right combo :D , I would say ...   Jun 10 2013, 05:26 PM
Steve   Do they make a 3/4 cam for a type 4? 3/4 cam has a...   Jun 10 2013, 05:33 PM
DBCooper   Do they make a 3/4 cam for a type 4? 3/4 cam has ...   Jun 10 2013, 06:05 PM
yeahmag   A few key components: * Aftermarket rods * Caref...   Jun 10 2013, 06:11 PM
Trekkor   This will be for endurance road racing. I would li...   Jun 10 2013, 09:22 PM
mittelmotor   That looks like the Buttonwillow ChumpCar race. Yo...   Jun 10 2013, 11:52 PM
Trekkor   That looks like the Buttonwillow ChumpCar race. Y...   Jun 11 2013, 02:27 PM
messix   endurance racing? don't go for high rpm! t...   Jun 11 2013, 12:11 AM
Mark Henry   There are limitations to what a pushrod motor can ...   Jun 11 2013, 06:25 AM
rick 918-S   There are limitations to what a pushrod motor can...   Jun 11 2013, 07:32 AM
Racer Chris   My backup 1.8L race engine is set up for 6800 rpm ...   Jun 11 2013, 07:06 AM
WLD419   You should post this question over on the Type4 f...   Jun 11 2013, 08:29 AM
Trekkor   I think our current set-up made 124hp. Can't r...   Jun 11 2013, 02:20 PM
Trekkor   It's a pretty fun car! http://www.914worl...   Jun 11 2013, 10:13 PM
stugray   Is there a "rule of thumb" for con-rod...   Jun 11 2013, 10:24 PM
messix   weight... the longer rod will weigh more. the is...   Jun 11 2013, 10:42 PM
Trekkor   More fun: http://www.914world.com/bbs2/uploads_of...   Jun 11 2013, 11:04 PM
Trekkor   That's probably my biggest complaint with the ...   Jun 11 2013, 11:41 PM
Trekkor   Dual Webers on the motor, BTW. KT   Jun 11 2013, 11:42 PM
messix   "floating the valves is not good!!...   Jun 11 2013, 11:52 PM
stugray   I thought that the problem occurred at the oppos...   Jun 12 2013, 01:22 AM
messix   I thought that the problem occurred at the oppo...   Jun 12 2013, 01:27 PM
r_towle   You might want to consider a 915 tranny, or a prop...   Jun 12 2013, 09:37 AM
Mark Henry   You might want to consider a 915 tranny, or a pro...   Jun 12 2013, 10:11 AM
Trekkor   Yes, maybe a 901 tailshifter with a flipped ring a...   Jun 12 2013, 08:38 PM
brant   Yes, maybe a 901 tailshifter with a flipped ring ...   Jun 12 2013, 09:17 PM
Trekkor   you don't have to flip it if you use a 911 ...   Jun 12 2013, 10:01 PM
DBCooper   Just a general question, what's the history of...   Jun 12 2013, 09:16 PM
Trekkor   Just a general question, what's the history o...   Jun 12 2013, 10:00 PM
messix   Just a general question, what's the history o...   Jun 12 2013, 10:11 PM
aircooledtechguy   If I build a motor to rev higher these are some of...   Jun 12 2013, 11:13 PM
messix   and would you run it for 24hrs in race trim? only...   Jun 12 2013, 11:45 PM
DBCooper   You said "we turned 322 3 mile laps in our 20...   Jun 13 2013, 10:29 AM
worn   Reason for the T1 suggestion was cost. All the ...   Jun 13 2013, 10:45 AM
DBCooper   What I think I am saying is that for power, I am ...   Jun 13 2013, 03:04 PM
Trekkor   You said "we turned 322 3 mile laps in our 2...   Jun 13 2013, 01:23 PM
yeahmag   I would completely disagree from experience. My Ty...   Jun 13 2013, 10:54 AM
DBCooper   Well, the T4 IS a truck motor, so it makes sense t...   Jun 13 2013, 12:43 PM
Racer Chris   I averaged over 60 mph for 1000 miles the last tim...   Jun 13 2013, 01:23 PM
Trekkor   We missed our class win by two laps. We were doin...   Jun 13 2013, 05:12 PM
stugray   I drove my 914 back & forth from Oklahoma Ci...   Jun 13 2013, 05:28 PM
messix   wow really guys :stooges: ... you cant compare cru...   Jun 13 2013, 05:53 PM
DBCooper   That is SO cool. Well done. I don't know wha...   Jun 14 2013, 08:10 AM
sean_v8_914   you must manage the FORCE force = mass x accelera...   Jun 14 2013, 11:24 AM
sean_v8_914   lots of cool valve float videos on youtube   Jun 14 2013, 11:31 AM
Trekkor   better view of the duct work!: http://www.914...   Jun 14 2013, 12:37 PM
DBCooper   Wow, reinforced bumpers welded on, looks like disc...   Jun 14 2013, 01:22 PM
Trekkor   Let's see if i can find some shots of the vent...   Jun 14 2013, 01:42 PM
Trekkor   http://www.914world.com/bbs2/uploads_offsite/i944....   Jun 14 2013, 04:42 PM
sean_v8_914   so I had to look at all teh pics on thet link, of ...   Jun 15 2013, 10:08 AM
sean_v8_914   that breather box is qustom HDR. the electrical co...   Jun 15 2013, 10:13 AM
Trekkor   Exactly! KT   Jun 15 2013, 11:33 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:14 PM
