> Removing Ball Joints, ball joint nut..where to get the tool?
jim912928
post Jul 9 2004, 08:27 AM
I'm going to be replacing the ball joints on my control arms...the control arms are off the car. This looks like it takes some weird socket with 4 notches on it. Since there is no porsche dealership even close to me...where does one get this tool? And are there any tricks to the trade I should know about before I start cranking on it?
Thanks in advance.
rhodyguy
post Jul 9 2004, 09:16 AM
soak the pins well and let the penetrent work. ifyou get the pins out/in without ruinning them (i did not), clean the pins and the hole they go into very well. oil the pin and the hole they go into. lightly tap the pins in fully with a drift. do not plan on pulling the pins in while you tighten the nut. if you do, you may need to order new ones. the pins are probably the most exspensive fastener i have ever purchased. (IMG:style_emoticons/default/sad.gif)
kevin
- Lo-Fi Version Time is now: 15th June 2026 - 05:34 AM
