| timothy_nd28 |
Jun 10 2013, 12:27 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
This is a tribute thread for the late Al Garcia, RIP
Many of us have issues with the inadequate lighting on our gauge cluster. This is a tutorial on how to increase the lighting for the DIY'er and for under 20 bucks. Euro911 was nice enough to be the guinea pig, in which he donated his gauges for this build. I rate the skill level at around a 3. 1 being easy (adding blinker fluid) and 10 (setting up valve geometry). 1st step, remove the combo/speedometer/tach from your car. Alrighty, easy enough. ![]() 2nd step, drink a beer or two. This is somewhat unnerving and for the few it may turn you off. However, this isn't all that bad. We need to remove the bezel trim rings. I'm sure there is a machine out there that cost 15k, that will do this in about 10 seconds but we will use a small screwdriver. The first time I did this (my gauges) it took around 40 mins each, and I had a good size blister on my index finger. You will get a feeling that you are absolutely ruining these rings, but your not. Wedge the screw driver in between the bezel and the gauge can. Once your in, lightly twist back and forth the screw drive in situ pushing in a forward direction. By the time you get to the third gauge, you'll be a pro! I also found that it is unnecessary to uncrimp the entire circumference of the bezel ring. Once you get 3/4 around, the last 1/4 will pop off. ![]() ![]() ![]() Now that these ring are off, go ahead and remove the insides. The tach will have 4 brass screws and the odometer will have 2. The combo gauge will have either 4 or 8 screws depending on the year. ![]() ![]() Now that the inner guts have been removed, you should have 3 empty cans like this ![]() We will need to clean the inside of these cans, for the best adhesion of the LED lights in a future step. I didn't use anything special, good old windex spray should suffice. ![]() |
| bperry |
Jun 12 2013, 11:15 PM
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
I re-did my '74 gauges (tach and speedo) back in the late 80's
I repainted the needles and cut out new glass for the tach. I was surprised that the tach used a plastic lens. I have a few words of caution when painting the needles. Make really sure that the paint on the needles is really really fully dry before you re-assemble the gauges. Perhaps even hit it with a heat gun a little bit to cure the paint. The problem I had was that soon after I put the gauges back in and the temperature got HOT here in Texas, the needles on the tach and speedometer started sticking to the resting post and they finally got permanently stuck. It SUCKED! I had to fully disassemble the gauges to free the needles. I ended up heat curing the paint a little bit and puting a tiny bit of vasoline on the post to prevent any future sticking. So far so good.... What really sucked about the speedo is that I already had to open it up twice before. - Once to fix the odometer to get it to work again. - A second time because when I was puting it back together for the odomenter fix, the original paint on the tip of the needle chipped off. (originally I wasn't planning on re-painting the needles) -- bill |
timothy_nd28 Gauge Lighting Jun 10 2013, 12:27 AM
timothy_nd28 Since the inside guts are out and very accessible,... Jun 10 2013, 12:27 AM
timothy_nd28 Towards the LED's, there is a plethora of styl... Jun 10 2013, 12:28 AM
timothy_nd28 Step 2 made me forget to take pictures of reassemb... Jun 10 2013, 12:28 AM
timothy_nd28 Here is the finished product. The camera made the... Jun 10 2013, 12:29 AM
r3dplanet :popcorn: Jun 10 2013, 12:38 AM
bulitt :beer2: Thx for posting this! Jun 10 2013, 01:54 AM
Chris H. Amazing work Tim! Thank you for the very deta... Jun 10 2013, 08:59 AM
76-914 Al would be proud of you. :poke: Now throw those... Jun 10 2013, 09:20 AM
ellisor3 Great Tribute Thread. Al was a great guy, helped ... Jun 10 2013, 09:34 AM
mrholland2 While my car is down, I would love to see the mult... Jun 10 2013, 10:22 AM
mrholland2 Oh, and are there LED instructions for the blinker... Jun 10 2013, 10:27 AM
timothy_nd28
Oh, and are there LED instructions for the blinke... Jun 10 2013, 10:33 PM
pcar916
The catch is finding a controller that turns on t... Jun 11 2013, 05:47 AM
Spoke Good write up.
Put this in the Classics Forum. Jun 10 2013, 10:36 AM
turk22 very nice write up!
Still scares the shat out... Jun 10 2013, 12:55 PM
poorsche914 Thanks for the write up. I have been planning to r... Jun 10 2013, 03:51 PM
euro911 Wow. No, I mean WOW!
I really didn't know... Jun 11 2013, 02:13 AM
Steve Thank you very much for posting this!!
I j... Jun 11 2013, 11:53 AM
Madswede This is a shoo-in for the "Classic" foru... Jun 11 2013, 01:53 PM
SUNAB914 Man, that is nice and I sold my cars/parts to Bill... Jun 11 2013, 02:00 PM
Mr.242
This is a tribute thread for the late Al Garcia, ... Jun 12 2013, 09:47 AM
timothy_nd28 Hey guys I have an idea for the next build. Same ... Jun 12 2013, 01:36 PM
bandjoey Does it help to paint the can inside? White? Sil... Jun 12 2013, 11:47 PM
timothy_nd28
Does it help to paint the can inside? White? Si... Dec 4 2013, 06:59 PM
Rob-O :agree:
I measured the glass and it seems to be ... Jun 13 2013, 08:14 AM
Rob-O Oh, three other points. When I restored mine (min... Jun 13 2013, 08:21 AM
timothy_nd28 :bump: This thread corresponds to my near future ... Jul 2 2013, 02:40 PM
scotty b
:bump: This thread corresponds to my near future... Jul 2 2013, 05:50 PM
gothspeed Simply amazing!!!! :trophy:
Thank... Dec 5 2013, 08:50 AM
PThompson509
Oh, and are there LED instructions for the blinke... Dec 9 2013, 10:08 PM
john77 Finally got all the parts to start this great DIY ... Feb 12 2015, 08:32 PM
euro911 ... and almost 2 years since Tim upgraded a set of... Mar 5 2015, 12:25 AM
Cuda911 Great work!!!
Regarding replacing the... Mar 5 2015, 02:44 AM
euro911 I swapped out most of the incandescent bulbs with ... Mar 5 2015, 08:41 PM
rnellums I'm really pumped. My Next-Gen LED gauges are ... Mar 5 2015, 08:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 10:06 AM |
