> 1.8--->2.0 Big Bore vs. stock 2.0, Cheeper to build a Big Bore from a 1.8?
thomasotten
post Jul 9 2004, 09:36 AM
I need some advise as to which direction to take my project. I have a 1.8 engine that is already out of my car. It could use a rebuild. I was wondering, for a street car with miild performance increases desired, what are the pros and cons of rebuilding a 1.8 engine to a big bore 2.0, as opposed to just buying a stock 2.0L and rebuilding that? Would I come out about the same, cost and performance wise? Either system will have 2.0L heat exhangers/exhaust.
tat2dphreak
post Jul 9 2004, 09:55 AM
stoya, stoya, stoya
the cost would be similar... you would have to factor in a crank too Sean... that ain't cheap...
if you already got the 1.8 though... it would be cheaper than finding a rebuildable 2.0... the heads alone make the 2.0 more expensive and you can get almost as good performace from 1.8 heads, esp if you open them up some with the money you save
- Lo-Fi Version Time is now: 1st July 2025 - 04:10 AM
