| Trekkor |
Jun 10 2013, 04:55 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I have a VW Bug race car with a type four motor.
I would like it to safely rev up to 6500-7000 rpms. What is needed to accomplish this? thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-c-a.akamaihd.net-1413-1370904931.1.jpg) KT |
| DBCooper |
Jun 13 2013, 12:43 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Well, the T4 IS a truck motor, so it makes sense they'd put it in the vans.
There are only two significant advantages the T1 design has over the T4 for performance, first being the exhaust port design, but the big second is the huge availability of not expensive performance parts. For example you can buy all new aftermarket aluminum cases that are beefed up in all the areas where the OEM case proved to be weak, forged cranks in every dimension, h-beam rods, brand new CNC milled heads in any port shape you want, etc, etc. That means these days you can build an ENTIRELY NEW T1 engine with all performance parts. I think you could probably build one to last, but that's not actually what I'm suggesting. I really just want to be clear about the actual needs, to make sure that the suggestions I make, that ALL of us make, are actually in line with the intentions and needs. If all you need to do is average 40 dependable miles an hour for 24 hours, for example, we may be overthinking and overspending all this. And the same's true to bump that up to just 60 mph, T4 or T1. So I'm just saying understand the really basic questions about need first, then the fun stuff (like spending Trek's money for him) later. |
Trekkor Making the type four rev higher Jun 10 2013, 04:55 PM
ConeDodger Extreme balance. Light driveline components. Ignor... Jun 10 2013, 05:00 PM
timothy_nd28 heavy duty valve springs and chrome moly pushrods Jun 10 2013, 05:02 PM
The Cabinetmaker My 2056 has the raby valve train kit with stock sp... Jun 10 2013, 05:13 PM
DBCooper All kinds of drag racers spinning them faster than... Jun 10 2013, 05:19 PM
ConeDodger
All kinds of drag racers spinning them faster tha... Jun 10 2013, 05:27 PM
WLD419 Some might say the right combo :D , I would say ... Jun 10 2013, 05:26 PM
Steve Do they make a 3/4 cam for a type 4?
3/4 cam has a... Jun 10 2013, 05:33 PM
DBCooper
3/4 cam has ... Jun 10 2013, 06:05 PM
yeahmag A few key components:
* Aftermarket rods
* Caref... Jun 10 2013, 06:11 PM
Trekkor This will be for endurance road racing.
I would li... Jun 10 2013, 09:22 PM
mittelmotor That looks like the Buttonwillow ChumpCar race. Yo... Jun 10 2013, 11:52 PM
Trekkor
That looks like the Buttonwillow ChumpCar race. Y... Jun 11 2013, 02:27 PM
messix endurance racing? don't go for high rpm! t... Jun 11 2013, 12:11 AM
Mark Henry There are limitations to what a pushrod motor can ... Jun 11 2013, 06:25 AM
rick 918-S
There are limitations to what a pushrod motor can... Jun 11 2013, 07:32 AM
Racer Chris My backup 1.8L race engine is set up for 6800 rpm ... Jun 11 2013, 07:06 AM
WLD419 You should post this question over on the Type4 f... Jun 11 2013, 08:29 AM
Trekkor I think our current set-up made 124hp.
Can't r... Jun 11 2013, 02:20 PM
Trekkor It's a pretty fun car!
http://www.914worl... Jun 11 2013, 10:13 PM
stugray
Is there a "rule of thumb" for con-rod... Jun 11 2013, 10:24 PM
messix weight...
the longer rod will weigh more.
the is... Jun 11 2013, 10:42 PM
Trekkor More fun:
http://www.914world.com/bbs2/uploads_of... Jun 11 2013, 11:04 PM
Trekkor That's probably my biggest complaint with the ... Jun 11 2013, 11:41 PM
Trekkor Dual Webers on the motor, BTW.
KT Jun 11 2013, 11:42 PM
messix "floating the valves is not good!!... Jun 11 2013, 11:52 PM
stugray
I thought that the problem occurred at the oppos... Jun 12 2013, 01:22 AM
messix
I thought that the problem occurred at the oppo... Jun 12 2013, 01:27 PM
r_towle You might want to consider a 915 tranny, or a prop... Jun 12 2013, 09:37 AM
Mark Henry
You might want to consider a 915 tranny, or a pro... Jun 12 2013, 10:11 AM
Trekkor Yes, maybe a 901 tailshifter with a flipped ring a... Jun 12 2013, 08:38 PM
brant
Yes, maybe a 901 tailshifter with a flipped ring ... Jun 12 2013, 09:17 PM
Trekkor
you don't have to flip it if you use a 911 ... Jun 12 2013, 10:01 PM
DBCooper Just a general question, what's the history of... Jun 12 2013, 09:16 PM
Trekkor
Just a general question, what's the history o... Jun 12 2013, 10:00 PM
messix
Just a general question, what's the history o... Jun 12 2013, 10:11 PM
aircooledtechguy If I build a motor to rev higher these are some of... Jun 12 2013, 11:13 PM
messix and would you run it for 24hrs in race trim? only... Jun 12 2013, 11:45 PM
DBCooper You said "we turned 322 3 mile laps in our 20... Jun 13 2013, 10:29 AM
worn
Reason for the T1 suggestion was cost. All the ... Jun 13 2013, 10:45 AM
DBCooper
What I think I am saying is that for power, I am ... Jun 13 2013, 03:04 PM
Trekkor
You said "we turned 322 3 mile laps in our 2... Jun 13 2013, 01:23 PM
yeahmag I would completely disagree from experience. My Ty... Jun 13 2013, 10:54 AM
Racer Chris I averaged over 60 mph for 1000 miles the last tim... Jun 13 2013, 01:23 PM
Trekkor We missed our class win by two laps.
We were doin... Jun 13 2013, 05:12 PM
stugray
I drove my 914 back & forth from Oklahoma Ci... Jun 13 2013, 05:28 PM
messix wow really guys :stooges: ... you cant compare cru... Jun 13 2013, 05:53 PM
DBCooper That is SO cool. Well done. I don't know wha... Jun 14 2013, 08:10 AM
sean_v8_914 you must manage the FORCE
force = mass x accelera... Jun 14 2013, 11:24 AM
sean_v8_914 lots of cool valve float videos on youtube Jun 14 2013, 11:31 AM
Trekkor better view of the duct work!:
http://www.914... Jun 14 2013, 12:37 PM
DBCooper Wow, reinforced bumpers welded on, looks like disc... Jun 14 2013, 01:22 PM
Trekkor Let's see if i can find some shots of the vent... Jun 14 2013, 01:42 PM
Trekkor http://www.914world.com/bbs2/uploads_offsite/i944.... Jun 14 2013, 04:42 PM
sean_v8_914 so I had to look at all teh pics on thet link, of ... Jun 15 2013, 10:08 AM
sean_v8_914 that breather box is qustom HDR. the electrical co... Jun 15 2013, 10:13 AM
Trekkor Exactly!
KT Jun 15 2013, 11:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:14 PM |
