| lsintampa |
Jun 30 2013, 09:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0
Will soon be backdating my exhaust with SS HE's I have new sealing rings (for the exhaust headers) and gaskets for the muffler, and new copper (plated) nuts or copper not sure but those from the big bird. I've read several threads about annealing the sealing rings, using copper RTV, and all sorts of ways you all have mounted up your HE's. The captain said something to the effect of mounting them, after you run them for a while, tighten them up again. I think in effect this is part of the annealing process. I think I'm going with annealing up front and then tighten them up again once they motor has been running a bit. Not sure this is the best method, or if one is better than the other, but it sounds right to me. Question I have, that I've not seen addressed anywhere is that when I take the stock headers and try to test fit them to the motor, it is really tight getting the headers onto the studs. So tight in fact, I never really got them onto the studs for fear of mucking something up in the process. By tight, I mead that the ears on the headers want to rub on the valve tubes. Is this "normal"? Thanks, Len And if you want to put your .02 in on the annealing / not annealing debate feel free! (IMG:style_emoticons/default/popcorn[1].gif) |
| stugray |
Jul 1 2013, 08:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE drop them directly into a mason jar of water and install. If you heat metal and cool it quickly you are not softening it, you are hardening it. To anneal (make the metal softer) you should heat them and then let them cool as slowly as possible. Stu |
| ChrisFoley |
Jul 1 2013, 08:53 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
If you heat metal and cool it quickly you are not softening it, you are hardening it. To anneal (make the metal softer) you should heat them and then let them cool as slowly as possible. Stu Depends on the metal you're working with and the grain structure they form at different temperatures. Your statement is generally true for steel alloys but not necessarily for other metals. Copper can be quenched in the hot annealed state and it will not harden. |
lsintampa To anneal or not to anneal? Jun 30 2013, 09:14 AM
rick 918-S anneal them Jun 30 2013, 09:30 AM
bulitt Shouldn't have to if they are new. :confused: Jun 30 2013, 09:38 AM
Black22 Anneal. Jun 30 2013, 09:46 AM
McMark Certainly doesn't hurt. But I don't do it... Jun 30 2013, 11:09 AM
mrbubblehead i say anneal. and use a dab of gasgacinch to hold ... Jun 30 2013, 06:50 PM
ThePaintedMan If logic holds true, and the heat in the exhaust a... Jun 30 2013, 07:00 PM
Rand Since it is proven that it is unnecessary, then wh... Jun 30 2013, 07:00 PM
ThePaintedMan It might be unnecessary, but it can't hurt, I ... Jun 30 2013, 07:14 PM
Rand Like I said, if it makes you feel better. (It... Jun 30 2013, 07:27 PM
lsintampa I didn't mean to start a fire storm... either ... Jun 30 2013, 07:35 PM
Rand
This... Jun 30 2013, 07:37 PM
ThePaintedMan No fire storm here. Just differing approaches I th... Jun 30 2013, 07:45 PM
lsintampa Hey George,
When the HE's get here (I hope so... Jun 30 2013, 07:55 PM
rhodyguy when dressing the piping you need a big bastard fi... Jul 1 2013, 05:39 AM
ThePaintedMan
If you heat metal and cool it quickly you are n... Jul 1 2013, 08:15 AM
worn
If you heat metal and cool it quickly you are n... Jul 1 2013, 02:26 PM
dlee6204
If you heat metal and cool it quickly you are n... Jul 1 2013, 08:44 AM
lsintampa ahh,
I'm firing up the grill right now.
Dogs... Jul 1 2013, 08:54 AM
bulitt
ahh,
Dog... Jul 1 2013, 09:29 AM
Racer Chris
ahh,
Do... Jul 1 2013, 09:57 AM
lsintampa Okay,
I think there was a great bit of informatio... Jul 1 2013, 10:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
