| BMartin914 |
Jul 11 2004, 04:38 PM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Just picked up my new 914 this morning.
Drove about 40 miles back home at an average speed of about 70. Ambient temp was probably 85 and the humidity very low, probably around 10 - 15%. My (stock) temp gauge was almost touching the red a good part of the way. Just on the edge of red when I got home. Should I be worried or do most teeners run this hot in this type of weather? I wouldn't expect it to behave like a water-cooler but is it running TOO hot? |
| SirAndy |
Jul 11 2004, 05:08 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(BMartin914 @ Jul 11 2004, 03:38 PM) I wouldn't expect it to behave like a water-cooler but is it running TOO hot? yes, it is ... altough the stock gauge is not all that useful, you shouldn't be that close to red on a 85 day. and because the car is new to you, you'll get to spend some qulity time with her! a few things to check (in that order): - make sure there's no dirt/leaves/other stuff blocking the cooling fins on the cylinders. - make sure the thermostat is working properly (and the flaps are not stuck). - make sure all the "warm air guides" are in place. - make sure it doesn't run lean. - make sure the timing is set OK. - what year is the car? if it doesn't have the rubber "flaps" in front of the cross-bar, add a pair of those. - make sure the fan isn't missing any blades. - does it get enough air? try running a few miles without engine lid. - air filter dirty? there might be more, that's all i can think of right now, (IMG:style_emoticons/default/driving.gif) Andy |
BMartin914 TOO HOT? Jul 11 2004, 04:38 PM
BMartin914
anthony Does "tuned to pass emissions" mean that he screwe... Jul 11 2004, 09:52 PM
BMartin914 The mechanic who passed the car wrote the followin... Jul 11 2004, 10:14 PM
Rob Ways I run at 250. Too hot. I need to install an oil co... Jul 11 2004, 10:15 PM
914ghost My 1.8 runs at 200 to 230 degrees for the most par... Jul 11 2004, 10:16 PM
Rockaria My 1975 1.8 L-Jet Runs on the hot side. But it dep... Jul 12 2004, 08:22 AM
jporsche914 Would it be worth the money to get an oil guage fo... Jul 12 2004, 10:30 AM
Jake Raby 180-225 is perfect..
225-245 is very warm and wil... Jul 12 2004, 11:40 AM
phantom914
Chris H. Sounds like old style. "Normal" is difficult to d... Jul 12 2004, 02:14 PM
Jake Raby Buy a real gauge with numbers on the face.... That... Jul 12 2004, 02:52 PM
phantom914 Mar 11 2005, 09:11 PM
Flat VW My 72' car does not have any guages and I real... Mar 11 2005, 10:31 PM
Flat VW http://www.914world.com/bbs2/ht... Mar 12 2005, 09:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
