> New carbs- one barrel pulling in too much air
tornik550
post Jul 1 2013, 07:45 PM
I purchased brand new weber 44 idf carbs from redline weber recently. I set everything equally between all barrels. I set the idle stop at 1/2 turn on both carbs. The engine started right up. I disconnected the linkage. Checked the air flow with a snail. Equal readings on cyl 1,2. Cyl 3 was pulling in so much air it was off the chart and cyl 4 was barely getting any air. I backed off the idle stop completely and I am still getting a huge amount of air in cyl 3 and almost none in cyl 4.
I took the carb off and visually inspected. Everything appears normal. Both butterflies appear closed.
FYI- I am certain that this is not a valve or cylinder problem. Everything was fine with my previous setup.
Any ideas?
McMark
post Jul 1 2013, 08:38 PM
914 Freak!
Not the first time I've seen new webers with throttle butterfly problems. If you pull that carb off, and hold it up to the light, I bet you'll see a HUGE gap between the throttle plate and the bore.
You can try loosening the screws that lock the plate to the throttle shaft and see if you can get them to sit better.
tornik550   New carbs- one barrel pulling in too much air   Jul 1 2013, 07:45 PM
kg6dxn   Temporarily swap the carbs right & left. If th...   Jul 1 2013, 08:12 PM
tornik550   Temporarily swap the carbs right & left. If t...   Jul 1 2013, 08:20 PM
brant   there is a balance adjustment screw between barrel...   Jul 1 2013, 08:16 PM
tornik550   there is a balance adjustment screw between barre...   Jul 1 2013, 08:22 PM
Dr Evil   Dang, Steve. You have a fecal touch with carbs.   Jul 1 2013, 08:28 PM
tornik550   Dang, Steve. You have a fecal touch with carbs. ...   Jul 1 2013, 09:23 PM
McMark   Not the first time I've seen new webers with t...   Jul 1 2013, 08:38 PM
ThePaintedMan   Not the first time I've seen new webers with ...   Jul 1 2013, 09:38 PM
rhodyguy   by balance adj you mean air bypass screws right? d...   Jul 2 2013, 06:45 AM
ThePaintedMan   by balance adj you mean air bypass screws right? ...   Jul 2 2013, 07:37 AM
McMark   Bad manufacturing seems to be a very good reason.   Jul 2 2013, 08:45 AM
Mblizzard   I bet you got the set that I sent back to Redline...   Jul 2 2013, 09:14 AM
yeahmag   This isn't necessarily abnormal. Close all the...   Jul 2 2013, 10:34 AM
rhodyguy   that is NOT a good nor a rational reason mark. ;) ...   Jul 2 2013, 11:24 AM
rhodyguy   to add to my post. closing all of the by-pass scre...   Jul 2 2013, 11:38 AM
yeahmag   It's just the opposite. With all the bleed scr...   Jul 2 2013, 12:05 PM
tornik550   It's just the opposite. With all the bleed sc...   Jul 2 2013, 12:17 PM
ThePaintedMan   One of the problems is that I cannot reduce the a...   Jul 2 2013, 12:27 PM
yeahmag   Now that... Is a problem. That sounds like a bad t...   Jul 2 2013, 12:23 PM
McMark   You can't really see if the throttle plates ar...   Jul 2 2013, 12:59 PM
stugray   you need to be very careful loosening those scre...   Jul 2 2013, 01:05 PM
rhodyguy   for heavens sake. how in the hell, with all 4 by-p...   Jul 3 2013, 08:11 AM
McMark   Sorry you're the one that's backwards. Al...   Jul 3 2013, 11:32 AM
Jake Raby   This was a common issue with the "Genuine...   Jul 3 2013, 01:42 PM
tornik550   I found a way to fix my problem. Return the carbs...   Jul 3 2013, 01:49 PM
tornik550   UPDATE- The issue appears to be that the throttle...   Jul 4 2013, 06:43 PM
McMark   They realized that because of their name reputatio...   Jul 4 2013, 11:56 PM
- Lo-Fi Version Time is now: 3rd September 2025 - 01:37 PM
