tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I purchased brand new weber 44 idf carbs from redline weber recently. I set everything equally between all barrels. I set the idle stop at 1/2 turn on both carbs. The engine started right up. I disconnected the linkage. Checked the air flow with a snail. Equal readings on cyl 1,2. Cyl 3 was pulling in so much air it was off the chart and cyl 4 was barely getting any air. I backed off the idle stop completely and I am still getting a huge amount of air in cyl 3 and almost none in cyl 4.
I took the carb off and visually inspected. Everything appears normal. Both butterflies appear closed. FYI- I am certain that this is not a valve or cylinder problem. Everything was fine with my previous setup. Any ideas? |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
QUOTE there is no reason for the plates to be misaligned. Bad manufacturing seems to be a very good reason. |
Lo-Fi Version | Time is now: 3rd September 2025 - 01:33 PM |
