> New carbs- one barrel pulling in too much air
tornik550
post Jul 1 2013, 07:45 PM
I purchased brand new weber 44 idf carbs from redline weber recently. I set everything equally between all barrels. I set the idle stop at 1/2 turn on both carbs. The engine started right up. I disconnected the linkage. Checked the air flow with a snail. Equal readings on cyl 1,2. Cyl 3 was pulling in so much air it was off the chart and cyl 4 was barely getting any air. I backed off the idle stop completely and I am still getting a huge amount of air in cyl 3 and almost none in cyl 4.
I took the carb off and visually inspected. Everything appears normal. Both butterflies appear closed.
FYI- I am certain that this is not a valve or cylinder problem. Everything was fine with my previous setup.
Any ideas?
rhodyguy
post Jul 2 2013, 11:38 AM
to add to my post. closing all of the by-pass screws and measuring the flow on each throat helps you find a baseline. you then have to bring the highest ones down to the lowest. not to exceed the max # of turns out (by passing the venturi) specified in thomlinson's weber manual.
tornik550   New carbs- one barrel pulling in too much air   Jul 1 2013, 07:45 PM
kg6dxn   Temporarily swap the carbs right & left. If th...   Jul 1 2013, 08:12 PM
tornik550   Temporarily swap the carbs right & left. If t...   Jul 1 2013, 08:20 PM
brant   there is a balance adjustment screw between barrel...   Jul 1 2013, 08:16 PM
tornik550   there is a balance adjustment screw between barre...   Jul 1 2013, 08:22 PM
Dr Evil   Dang, Steve. You have a fecal touch with carbs.   Jul 1 2013, 08:28 PM
tornik550   Dang, Steve. You have a fecal touch with carbs. ...   Jul 1 2013, 09:23 PM
McMark   Not the first time I've seen new webers with t...   Jul 1 2013, 08:38 PM
ThePaintedMan   Not the first time I've seen new webers with ...   Jul 1 2013, 09:38 PM
rhodyguy   by balance adj you mean air bypass screws right? d...   Jul 2 2013, 06:45 AM
ThePaintedMan   by balance adj you mean air bypass screws right? ...   Jul 2 2013, 07:37 AM
McMark   Bad manufacturing seems to be a very good reason.   Jul 2 2013, 08:45 AM
Mblizzard   I bet you got the set that I sent back to Redline...   Jul 2 2013, 09:14 AM
yeahmag   This isn't necessarily abnormal. Close all the...   Jul 2 2013, 10:34 AM
rhodyguy   that is NOT a good nor a rational reason mark. ;) ...   Jul 2 2013, 11:24 AM
rhodyguy   to add to my post. closing all of the by-pass scre...   Jul 2 2013, 11:38 AM
yeahmag   It's just the opposite. With all the bleed scr...   Jul 2 2013, 12:05 PM
tornik550   It's just the opposite. With all the bleed sc...   Jul 2 2013, 12:17 PM
ThePaintedMan   One of the problems is that I cannot reduce the a...   Jul 2 2013, 12:27 PM
yeahmag   Now that... Is a problem. That sounds like a bad t...   Jul 2 2013, 12:23 PM
McMark   You can't really see if the throttle plates ar...   Jul 2 2013, 12:59 PM
stugray   you need to be very careful loosening those scre...   Jul 2 2013, 01:05 PM
rhodyguy   for heavens sake. how in the hell, with all 4 by-p...   Jul 3 2013, 08:11 AM
McMark   Sorry you're the one that's backwards. Al...   Jul 3 2013, 11:32 AM
Jake Raby   This was a common issue with the "Genuine...   Jul 3 2013, 01:42 PM
tornik550   I found a way to fix my problem. Return the carbs...   Jul 3 2013, 01:49 PM
tornik550   UPDATE- The issue appears to be that the throttle...   Jul 4 2013, 06:43 PM
McMark   They realized that because of their name reputatio...   Jul 4 2013, 11:56 PM
- Lo-Fi Version Time is now: 3rd September 2025 - 01:32 PM
