Custom Gauge lighting, now in color! |
timothy_nd28 |
Jul 2 2013, 04:00 PM
First I would like to thank Kent (76-914) for introducing me to Al's wife Shirlee. She was extremely helpful and sold me all of Al's leftovers. Today, I received a huge box filled with led's, cannibalized gauge housings and a very touching note from Shirlee. I also noticed a dismantled tachometer that Al was working on. I was taken back and felt very sad seeing this tach. You could see all the tedious prep work that Al did, but sadly he wasn't able to complete his masterpiece.
I was determined this afternoon to pick-up where Al had left off, in his honor. This thread is broken up in 3 parts. The first part is intended to show everyone how Al achieved his multicolor gauges. The 2nd part is a "how to" to make your gauges into any color you wish. The last part is another "how to" but taking our gauges to a whole new level. As you will see, my design could have a back light color background in any color that you can think of. My uncle has designed a neat little circuit that works in tandem with the RGB color controller. The circuit senses the tach wire, and changes the color of the back-lighting of all gauges to yellow at a certain rpm, then red at another certain rpm. It is fully customizable as you can set the when yellow comes on, as well as the red. There is another input on this circuit board which turns all the gauges to red when triggered. I thought we could use this special input for the low fuel light, or as a fan belt warning for the 911 types. Perhaps the special input could be hacked into a radar detector, many possibilities. Yellow and redline lights again are fully adjustable via a potentiometers, also this circuit will work for any 4-6-8 cylinder engines. With my last how-to topic, I received many messages from folks that didn't feel comfortable doing this to their own gauges. I have done enough of these in which I feel comfortable. If you're one of these folks, send me a PM and I'll do this conversion for you. For me, it's a 1.5 hour process, but it may take longer for someone that has never done something like this before. I'll try to make this write up detailed as much as possible. |
timothy_nd28 |
Jul 2 2013, 04:01 PM
Here is Al's unfinished gauge, most likely a 75-76 era tachometer
Keep in mind, this is what we are after I applied power to this gauge, and here was the results As you can see, this partial led strip is white. I'm not sure what Al was trying to do, but for his signature multicolor gauge, this is the wrong color. 1st step, reinstall the tach faceplate and make pencil marks inside the can at the RPM's you want. I chose 0 to 4.2 to be blue, 4.2 to redline to be white, then redline to around 7 to be red. The pencil line inside the gauge can is helpful with the mock up. Here is a picture of the style flexible LED strip Al used. I was happy to see that he used the same style side emitting led as I did, but his is not waterproof. I'm not a huge fan with this idea, due to the possibility of something shorting to ground. Our car catches fire readily enough, I hate to add to the list of potential fire starting causes. This is why I use waterproof led flex strips. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:47 AM |
