| timothy_nd28 |
Jul 2 2013, 04:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
First I would like to thank Kent (76-914) for introducing me to Al's wife Shirlee. She was extremely helpful and sold me all of Al's leftovers. Today, I received a huge box filled with led's, cannibalized gauge housings and a very touching note from Shirlee. I also noticed a dismantled tachometer that Al was working on. I was taken back and felt very sad seeing this tach. You could see all the tedious prep work that Al did, but sadly he wasn't able to complete his masterpiece.
I was determined this afternoon to pick-up where Al had left off, in his honor. This thread is broken up in 3 parts. The first part is intended to show everyone how Al achieved his multicolor gauges. The 2nd part is a "how to" to make your gauges into any color you wish. The last part is another "how to" but taking our gauges to a whole new level. As you will see, my design could have a back light color background in any color that you can think of. My uncle has designed a neat little circuit that works in tandem with the RGB color controller. The circuit senses the tach wire, and changes the color of the back-lighting of all gauges to yellow at a certain rpm, then red at another certain rpm. It is fully customizable as you can set the when yellow comes on, as well as the red. There is another input on this circuit board which turns all the gauges to red when triggered. I thought we could use this special input for the low fuel light, or as a fan belt warning for the 911 types. Perhaps the special input could be hacked into a radar detector, many possibilities. Yellow and redline lights again are fully adjustable via a potentiometers, also this circuit will work for any 4-6-8 cylinder engines. With my last how-to topic, I received many messages from folks that didn't feel comfortable doing this to their own gauges. I have done enough of these in which I feel comfortable. If you're one of these folks, send me a PM and I'll do this conversion for you. For me, it's a 1.5 hour process, but it may take longer for someone that has never done something like this before. I'll try to make this write up detailed as much as possible. |
| monkeyboy |
Jul 2 2013, 11:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I'd be in for a set.
timothy_nd28 Custom Gauge lighting Jul 2 2013, 04:00 PM
timothy_nd28 Here is Al's unfinished gauge, most likely a 7... Jul 2 2013, 04:01 PM
timothy_nd28 Next, we need to build a continuous strip with dif... Jul 2 2013, 04:01 PM
timothy_nd28 I have spoken my piece about using non waterproof ... Jul 2 2013, 04:01 PM
timothy_nd28 Now, just reassemble. Refer to my other topic and... Jul 2 2013, 04:01 PM
timothy_nd28 Now onto true multicolor gauges! This part ex... Jul 2 2013, 04:02 PM
timothy_nd28
be sure to use heat shrink over your solder ... Jul 2 2013, 04:02 PM
timothy_nd28 Go ahead and test these lights before putting the ... Jul 2 2013, 04:03 PM
timothy_nd28
Totally up to you. Now if you are happy wit... Jul 2 2013, 04:03 PM
timothy_nd28 Here is the board artwork for the circuitboard whi... Jul 2 2013, 04:03 PM
montoya 73 2.0 Nice job :thumbsup:
This part II thread should al... Jul 2 2013, 05:54 PM
timothy_nd28
Nice job :thumbsup:
This part II thread should a... Jul 2 2013, 06:06 PM
DBCooper Wow. I guess to be an electronics whiz you need to... Jul 2 2013, 08:07 PM
timothy_nd28 No eyesight needed, I'm trying to make this as... Jul 2 2013, 08:24 PM
timothy_nd28 Here is the RGB controller box with its board pull... Jul 2 2013, 08:48 PM
ThePaintedMan Tim, this is cool as Fuchs man. Al would be proud ... Jul 2 2013, 08:50 PM
timothy_nd28
Tim, this is cool as Fuchs man. Al would be proud... Jul 2 2013, 08:52 PM
Tim, this is cool as Fuchs man. Al would be prou... Jul 3 2013, 07:10 AM
SirAndy :trophy: Jul 2 2013, 08:56 PM
Mr.242 Simply amazing! A cool simple add on to the 4... Jul 2 2013, 09:08 PM
DBCooper Unfortunately my gauges are all non-stock or I... Jul 2 2013, 09:17 PM
timothy_nd28 Here's what inspired my thinking.
k2K2c3QQgSA... Jul 2 2013, 09:17 PM
StratPlayer I'm interested.... Jul 2 2013, 09:19 PM
timothy_nd28 SirAndy, you do so much for this site. I would be ... Jul 3 2013, 12:11 AM
SirAndy SirAndy, you do so much for this site. I would be ... Jul 22 2013, 11:31 AM
Harpo Kit and Labor
(Members)............(Cylinders)....... Jul 22 2013, 06:51 PM
76-914 Thx Buddy, Al has got to be smiling. He loved doin... Jul 3 2013, 08:21 AM
timothy_nd28 That or he's gonna come haunt me for giving up... Jul 3 2013, 04:06 PM
boogie_man Those look very, very good. Great workmanship :Q... Jul 3 2013, 04:59 PM
timothy_nd28 Ok, I have been going over prices for this. As of... Jul 3 2013, 11:05 PM
mrholland2 I'm in for this!!!!!!... Jul 3 2013, 11:49 PM
914socal I'm in for a kit and your labor service! Jul 4 2013, 12:10 AM
monkeyboy I'm in for an installed kit. Jul 4 2013, 02:30 PM
Harpo I'm in for the kit & your install services... Jul 4 2013, 05:15 PM
Madswede I'm in for a kit! This should work with my... Jul 5 2013, 11:21 AM
timothy_nd28 Great! This circuit is very diverse as it was... Jul 5 2013, 12:20 PM
Mr.242 The 'do it yourself' kit....are all the pi... Jul 6 2013, 11:39 AM
timothy_nd28 It would be mighty cruel of me to give you a board... Jul 6 2013, 03:37 PM
timothy_nd28 I should be clearer. If you want the kit and for m... Jul 6 2013, 03:59 PM
poorsche914 Count me in for a kit. Does it include the LED str... Jul 6 2013, 06:22 PM
timothy_nd28 Yep, the DIY kit will have enough led strip to do... Jul 6 2013, 06:55 PM
timothy_nd28 Some progress today, the circuit boards have arriv... Jul 17 2013, 11:46 AM
Mr.242 Do you have a time turn around on your work on a s... Jul 17 2013, 11:55 AM
timothy_nd28 Turn around time will be one day. I'd hate to... Jul 17 2013, 11:59 AM
lonewolfe Put me down for one set including your labor. Can ... Jul 17 2013, 02:00 PM
lonewolfe
Put me down for one set including your labor. Can... Jul 17 2013, 02:02 PM
timothy_nd28
Put me down for one set including your labor. Ca... Jul 17 2013, 02:29 PM
mepstein Put me down for a kit. DIY, Let me know when you w... Jul 17 2013, 06:44 PM
timothy_nd28 Got the prototype circuit board soldered up today.... Jul 19 2013, 09:34 PM
timothy_nd28 I have the redline red light to activate around 55... Jul 19 2013, 09:58 PM
mrholland2 What's a good shift point? Mom's 64 Lemans... Jul 19 2013, 10:57 PM
monkeyboy I am usually getting ready to shift at 5,000. Then... Jul 19 2013, 11:11 PM
timothy_nd28 Both lights are adjustable. I'll adjust the co... Jul 19 2013, 11:12 PM
Both lights are adjustable. I'll adjust the c... Jul 20 2013, 03:42 AM
euro911 Wow, Tim ... I just saw this particular thread and... Jul 20 2013, 05:19 AM
rick 918-S Very cool Jul 20 2013, 07:01 AM
eric9144 Can you do the small center console gauges as well... Jul 20 2013, 08:57 AM
zambezi This is going to be really cool. I will definitel... Jul 20 2013, 10:02 AM
timothy_nd28 I haven't opened up the smaller console gauges... Jul 20 2013, 10:03 AM
Harpo This is very impressive. Looking forward to this ... Jul 20 2013, 10:39 AM
mikeyb33 Amazing, fantastic work!
Would be interested ... Jul 20 2013, 11:07 AM
monkeyboy Quick question about the gauge color change. Just ... Jul 21 2013, 09:29 AM
timothy_nd28
Quick question about the gauge color change. Just... Jul 21 2013, 03:28 PM
euro911 I want mine to come on when I get a bright idea
Jul 21 2013, 09:41 AM
monkeyboy
... Jul 21 2013, 10:15 AM
euro911 I have plenty of burned out light bulbs here for y... Jul 21 2013, 07:51 PM
timothy_nd28 Okay, I recorded some video last night. I'm a... Jul 21 2013, 03:20 PM
Gary Please put me down for a DIY. I'll need enough... Jul 22 2013, 05:09 AM
timothy_nd28 Research and development phase is just about over.... Jul 22 2013, 11:24 AM
timothy_nd28 Right now I'm just doing the first 10 members ... Jul 22 2013, 01:54 PM
mrholland2 Hi,
I'm in the process of a major car project... Jul 22 2013, 02:04 PM
SirAndy [b]Kit and Labor(Members)............(Cylinders)..... Jul 22 2013, 02:28 PM
timothy_nd28
[b]Kit and Labor(Members)............(Cylinders).... Jul 22 2013, 02:37 PM
SirAndy Nice, I'll replace that plastic lens with some... Jul 22 2013, 11:35 PM
SirAndy Oh, one more thing, i have 5 gauges, not 3, since ... Jul 22 2013, 11:37 PM
monkeyboy I am in... How do we send you our gauges, and your... Jul 22 2013, 02:07 PM
timothy_nd28
I am in... How do we send you our gauges, and you... Jul 22 2013, 02:10 PM
eric9144 Can you change the speedo gearing to match a tire ... Jul 22 2013, 03:59 PM
timothy_nd28
Can you change the speedo gearing to match a tire... Jul 22 2013, 06:45 PM
ThePaintedMan Sorry Tim, got your message but it got crazy at wo... Jul 22 2013, 08:22 PM
timothy_nd28 I need two more volunteers for the kit+labor to co... Jul 22 2013, 10:54 PM
Jakeodoule
I need two more volunteers for the kit+labor to c... Jul 23 2013, 05:41 PM
timothy_nd28 Those are cool, just might keep them! I see n... Jul 23 2013, 07:39 AM
timothy_nd28 Kit and Labor (*)= first 10 orders with price @ ... Jul 23 2013, 05:52 PM
no1uno I'd like to see the light. Include me for an ... Jul 23 2013, 07:20 PM
timothy_nd28
I'd like to see the light. Include me for an... Jul 24 2013, 12:03 AM
balljoint :idea:
The tach in my 914 has a little orange mar... Jul 23 2013, 08:25 PM
timothy_nd28 If anyone can replicate this for me, I would so gi... Jul 24 2013, 01:15 AM
euro911 If anyone can replicate this for me, I would so gi... Jul 24 2013, 08:16 PM
timothy_nd28 Here's the remote that comes with the controll... Jul 24 2013, 07:59 PM
timothy_nd28 :agree:
Alrighty, I'm ready for the lucky fi... Jul 24 2013, 08:52 PM
timothy_nd28 One last question for my first 10 group buyers. ... Jul 24 2013, 10:35 PM
Jakeodoule Mine is all stock.
One last question for my firs... Jul 25 2013, 01:12 PM
balljoint My car is all stock. Jul 25 2013, 08:16 AM
monkeyboy I have an ignition system on my car, but I am runn... Jul 25 2013, 10:31 AM
mrholland2 Stock Jul 25 2013, 01:31 PM
rdauenhauer Put me down for the full meal deal ...Kit and Labo... Jul 25 2013, 01:59 PM
porkchopexpress Outstanding work Tim! I am sure Al would be v... Jul 28 2013, 11:58 AM
Mblizzard At some point I am going to have to have this... Jul 28 2013, 07:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 05:57 AM |
