| 914ltd |
Oct 6 2011, 06:34 AM
Member ![]() ![]() Group: Members Posts: 247 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
I posted this previously, heating season is here again. These are big cracks, a tiny one you would not be able to hear would still be dangerous. These are not accident damaged. If you have a set on your car, grab the carbon monoxide detector from home and take a ride with the heat on and windows rolled up. There is a detector used in small aircraft also available. The last photo is how we now test for leaks using air pressure. Brad
This post is still relevant today some 15 years since I first posted it. A large number of these early SSI's are still around in parts stashes and yet to be restored 914's. The currently available heats are most likely safe. I have not found anything similar in a stock, even rusty heat exchanger. STAY SAFE! Brad Mayeur Attached image(s)
| Jgilliam914 |
Jul 5 2013, 07:17 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,376 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
I have never had that tight of a car to worry about CO or drove it often enough in the cold enough to want heat (IMG:style_emoticons/default/sunglasses.gif) But I would be interested in seeing the gas heater in action
914ltd SSI heat exchanger warning Oct 6 2011, 06:34 AM
mepstein So just the shell is stainless? Oct 6 2011, 06:43 AM
914ltd
Jim The whole h... Oct 6 2011, 09:04 AM
SLITS
Jim The whole ... Oct 6 2011, 09:14 AM
rick 918-S Thanks Brad! I have seen a set like that. Just... Oct 6 2011, 06:50 AM
jimkelly i believe the pipes are stainless too - a magnet s... Oct 6 2011, 06:51 AM
914ltd
i believe the pipes are stainless too - a magnet ... Oct 6 2011, 09:22 AM
wingnut86 Just assuming here, but is the washer/rubber dongl... Oct 6 2011, 07:27 AM
rick 918-S
Just assuming here, but is the washer/rubber dong... Oct 6 2011, 07:40 AM
VRROOMM1
Just assuming here, but is the washer/rubber dong... Oct 6 2011, 07:42 AM
76-914
Just assuming here, but is the washer/rubber dong... Oct 6 2011, 07:47 AM
wingnut86 Great responses. All noted in my broken Carolina ... Oct 6 2011, 07:52 AM
tradisrad I've seen a cracked one. Oct 6 2011, 07:53 AM
dlee6204 This is a great thing to check. Thanks for postin... Oct 6 2011, 08:16 AM
jaxdream One way of using this method is to hold each pluge... Oct 6 2011, 09:31 AM
avidfanjpl Sounds like we should see if someone is willing to... Oct 6 2011, 12:11 PM
Sounds like we should see if someone is willing t... Oct 6 2011, 03:12 PM
poorsche914 I had a 1.7 set of SSIs on my 914 and after many a... Nov 11 2011, 12:21 PM
914ltd Let me suggest you don't repair the bad SSI... Nov 11 2011, 01:47 PM
poorsche914 Let me suggest you don't repair the bad SSI... Nov 11 2011, 03:53 PM
69rsss
Sounds like we should see if someone is willing ... Nov 18 2011, 12:50 AM
flipb I've previously gotten oil (from a leak) into ... Oct 6 2011, 12:21 PM
GeorgeRud As these cars age, things do wear out. Even thing... Oct 6 2011, 01:44 PM
RFoulds if you dont need the heat, simply remove the hose ... Oct 6 2011, 02:00 PM
ConeDodger Some where all stainless others were not. I recall... Oct 6 2011, 02:33 PM
Mikey914 A simple cheap insurance is one of these. You can ... Nov 11 2011, 12:57 PM
sixnotfour my daily driver I switched to gas heat, Nice dry c... Nov 11 2011, 02:04 PM
GeorgeRud If you have any pictures of your gas heater and it... Nov 11 2011, 10:32 PM
bigkensteele I just put my car back together and drove it for t... Nov 17 2011, 10:10 PM
GeorgeRud You could get a CO detector card, turn the heat on... Nov 17 2011, 10:23 PM
bigkensteele I picked this up at HD Racing today. $28 is ... Nov 18 2011, 07:00 PM
jaxdream
I picked this up at HD Racing today. $28 is... Nov 18 2011, 10:58 PM
RobW Thanks for posting this nugget.
We all love our ... Nov 19 2011, 05:26 AM
nathansnathan I found something similar on a pair of factory bus... Nov 19 2011, 10:25 AM
wingnut86 :WTF:
Racer Chris's custom headers with heat... Nov 19 2011, 08:35 PM
partwerks One less thing for me to worry about having the WR... Nov 19 2011, 08:49 PM
jimkelly my first encounter with a sshe that had a crack in... Mar 15 2012, 04:10 PM
bandjoey What About the common steel HE's? Do they cra... Mar 15 2012, 06:43 PM
bigkensteele Thanks to Brad and this thread, I don't drive ... Mar 15 2012, 06:57 PM
2xs performance Great thread!
This is my first air-cooled car... Mar 15 2012, 07:44 PM
sean_v8_914 2013 bump on an important thread Jul 4 2013, 03:49 PM
michael7810 Thanks for the bump. Today I removed my stock HXs... Jul 4 2013, 05:11 PM
euro911 I'm back to thinking about electric heaters fo... Jul 4 2013, 08:29 PM
Mark Henry
I'm back to thinking about electric heaters f... Jul 5 2013, 07:04 AM
euro911
I'm back to thinking about electric heaters f... Jul 5 2013, 12:05 PM
Maltese Falcon Last year Dansk purchased the SSI brand and added ... Jul 4 2013, 09:53 PM
bigkensteele $28 O2 sensor that could save your life
:be... Jul 4 2013, 11:37 PM
euro911 Good reviews too. Jul 5 2013, 01:17 AM
GeorgeRud Webasto and Eberspacher are the two most common on... Jul 5 2013, 07:24 AM
mepstein heated seats Jul 5 2013, 07:27 AM
Garold Shaffer :bump:
Just wanted to give this thread a bump si... Oct 23 2013, 06:21 AM
JmuRiz All I wish is that SSI (the new one) would make so... Oct 23 2013, 07:49 AM
All I wish is that SSI (the new one) would make s... Oct 23 2013, 08:23 AM
mr914 There is ferrous and non-ferrous stainless.
Best ... Oct 24 2013, 02:12 AM
Since the weather is starting to cool off... Sep 24 2014, 10:07 AM
buck toenges
:bump:
Since the weather is starting to cool of... Sep 24 2014, 11:48 AM
KaptKaos Just saw this, and it may explain the leak that I ... Sep 24 2014, 10:41 AM
euro911
Just saw this, and it may explain the leak that I... Sep 24 2014, 08:42 PM
GeorgeRud If the exchangers are on the car, a simple battery... Sep 24 2014, 12:23 PM
barefoot
I posted this last year, heating season is here a... Sep 24 2014, 06:18 PM
RobW Yikes! Forget heat then... :unsure: Sep 24 2014, 09:51 PM
Phoenix914 Here is a link to another battery operated CO dete... Sep 25 2014, 05:51 AM
Spoke ??? Mar 5 2015, 01:02 PM
ThePaintedMan That looks just like a set I bought off of Ebay...... Mar 5 2015, 01:26 PM
Garold Shaffer Yep, had a perfect looking set of 2.0l exchangers ... Mar 5 2015, 07:18 PM
nathansnathan Whenever I bolt the heat exchangers to a motor, I ... Sep 25 2015, 04:25 PM
Johny Blackstain Anyone have a clue as to who made them for "A... Sep 25 2015, 04:30 PM
Dave_Darling I'm pretty sure that SSI made all of the 914 f... Sep 25 2015, 06:19 PM
SirAndy I'm pretty sure that SSI made all of the 914 f... Sep 25 2015, 07:06 PM
dr914@autoatlanta.com Right Dave, John Danials at Stainless Systems made... Jan 30 2019, 09:27 AM
Johny Blackstain
I'm pretty sure that SSI made all of the 914 ... Sep 25 2015, 07:15 PM
Katmanken Don't think so. A metalurgist for GE aircraft ... Sep 25 2015, 09:36 PM
bretth So are you saying that if it is not magnetic it is... Sep 26 2015, 06:36 AM
porschetub
I posted this last year, heating season is here a... Sep 26 2015, 02:43 AM
RobW Tangerine or headers.Not the end of the world. Sep 26 2015, 06:07 AM
barefoot I just checked my 1.7/1.8 SSI's and neither th... Sep 26 2015, 07:01 AM
914ltd Hey 'teeners, It's time to bring this up a... Oct 1 2015, 07:15 AM
GaroldShaffer Little late in bumping this thread. Never to late ... Jan 29 2019, 10:58 PM
914ltd
Little late in bumping this thread. Never to late... Jan 30 2019, 08:56 AM
mb911 This rule is for any and all heat exchangers.. Kee... Jan 30 2019, 10:11 AM
Dave_Darling We have just seen an SSI on the Facebook group tha... Jan 30 2019, 11:44 AM
mb911
We have just seen an SSI on the Facebook group th... Jan 30 2019, 12:13 PM
GeorgeRud You can get a battery powered CO detector for ... Jan 30 2019, 05:51 PM
worn
You can get a battery powered CO detector for ... Jan 30 2019, 07:55 PM
euro911 You can get a battery powered CO detector for ... Jan 31 2019, 02:36 AM
Mark Henry
You can get a battery powered CO detector for ... Jan 31 2019, 08:01 AM
StratPlayer Who is making SS exchangers? Jan 30 2019, 08:01 PM
mb911
For a 4cyl no idea... Jan 30 2019, 08:37 PM
DRPHIL914
For a 4cyl no ide... Jan 31 2019, 07:07 AM
euro911 Those are cool ... I'll have to get a couple o... Jan 31 2019, 12:25 PM
914ltd I wanted to post this again. I was just reminded w... Oct 15 2020, 12:20 PM
rbzymek Thanks for the heads up. Just ordered a $20 ... Oct 15 2020, 03:22 PM
horizontally-opposed Yikes.
This thread is a good reminder to find ot... Oct 15 2020, 05:28 PM
Yikes.
This thread is a good reminder to find o... Oct 16 2020, 06:18 AM
euro911 Yep. I have a pair of 914 Rubber's seat heater... Oct 16 2020, 01:35 AM
mb911 Ask Michael about heat in his car or Steve or any ... Oct 16 2020, 08:07 AM
We are actually working on a simpler hopefully ch... Oct 16 2020, 09:28 AM
horizontally-opposed I don't at all disagree that heat exchangers a... Oct 16 2020, 08:42 AM
914ltd The header pipes can be filled with water to check... Oct 16 2020, 09:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 03:12 PM |
