> Custom Gauge lighting, now in color!
timothy_nd28
post Jul 2 2013, 04:00 PM
First I would like to thank Kent (76-914) for introducing me to Al's wife Shirlee. She was extremely helpful and sold me all of Al's leftovers. Today, I received a huge box filled with led's, cannibalized gauge housings and a very touching note from Shirlee. I also noticed a dismantled tachometer that Al was working on. I was taken back and felt very sad seeing this tach. You could see all the tedious prep work that Al did, but sadly he wasn't able to complete his masterpiece.
I was determined this afternoon to pick-up where Al had left off, in his honor. This thread is broken up in 3 parts. The first part is intended to show everyone how Al achieved his multicolor gauges. The 2nd part is a "how to" to make your gauges into any color you wish. The last part is another "how to" but taking our gauges to a whole new level. As you will see, my design could have a back light color background in any color that you can think of. My uncle has designed a neat little circuit that works in tandem with the RGB color controller. The circuit senses the tach wire, and changes the color of the back-lighting of all gauges to yellow at a certain rpm, then red at another certain rpm. It is fully customizable as you can set the when yellow comes on, as well as the red. There is another input on this circuit board which turns all the gauges to red when triggered. I thought we could use this special input for the low fuel light, or as a fan belt warning for the 911 types. Perhaps the special input could be hacked into a radar detector, many possibilities. Yellow and redline lights again are fully adjustable via a potentiometers, also this circuit will work for any 4-6-8 cylinder engines.
With my last how-to topic, I received many messages from folks that didn't feel comfortable doing this to their own gauges. I have done enough of these in which I feel comfortable. If you're one of these folks, send me a PM and I'll do this conversion for you. For me, it's a 1.5 hour process, but it may take longer for someone that has never done something like this before. I'll try to make this write up detailed as much as possible.
Madswede
post Jul 5 2013, 11:21 AM
Flat Out Driver
I'm in for a kit! This should work with my gauges I believe, which are standard except the tach is appropriate for a /6.
Tangent: got two oil gauges and volt gauge separated out. They're brighter (well, except oil temp) than the ones on the main dash so they're not too bad, but I'd like to brighten up the oil temp seeing as it's sort of important. Think I might try to salvage lights from the other gauges.
timothy_nd28   Custom Gauge lighting   Jul 2 2013, 04:00 PM
timothy_nd28   Here is Al's unfinished gauge, most likely a 7...   Jul 2 2013, 04:01 PM
timothy_nd28   Next, we need to build a continuous strip with dif...   Jul 2 2013, 04:01 PM
timothy_nd28   I have spoken my piece about using non waterproof ...   Jul 2 2013, 04:01 PM
timothy_nd28   Now, just reassemble. Refer to my other topic and...   Jul 2 2013, 04:01 PM
timothy_nd28   Now onto true multicolor gauges! This part ex...   Jul 2 2013, 04:02 PM
timothy_nd28   be sure to use heat shrink over your solder ...   Jul 2 2013, 04:02 PM
timothy_nd28   Go ahead and test these lights before putting the ...   Jul 2 2013, 04:03 PM
timothy_nd28   Totally up to you. Now if you are happy wit...   Jul 2 2013, 04:03 PM
timothy_nd28   Here is the board artwork for the circuitboard whi...   Jul 2 2013, 04:03 PM
montoya 73 2.0   Nice job :thumbsup: This part II thread should al...   Jul 2 2013, 05:54 PM
timothy_nd28   Nice job :thumbsup: This part II thread should a...   Jul 2 2013, 06:06 PM
DBCooper   Wow. I guess to be an electronics whiz you need to...   Jul 2 2013, 08:07 PM
timothy_nd28   No eyesight needed, I'm trying to make this as...   Jul 2 2013, 08:24 PM
timothy_nd28   Here is the RGB controller box with its board pull...   Jul 2 2013, 08:48 PM
ThePaintedMan   Tim, this is cool as Fuchs man. Al would be proud ...   Jul 2 2013, 08:50 PM
timothy_nd28   Tim, this is cool as Fuchs man. Al would be proud...   Jul 2 2013, 08:52 PM
mepstein   Tim, this is cool as Fuchs man. Al would be prou...   Jul 3 2013, 07:10 AM
SirAndy   :trophy:   Jul 2 2013, 08:56 PM
Mr.242   Simply amazing! A cool simple add on to the 4...   Jul 2 2013, 09:08 PM
DBCooper   Unfortunately my gauges are all non-stock or I...   Jul 2 2013, 09:17 PM
timothy_nd28   Here's what inspired my thinking. k2K2c3QQgSA...   Jul 2 2013, 09:17 PM
StratPlayer   I'm interested....   Jul 2 2013, 09:19 PM
monkeyboy   I'd be in for a set.   Jul 2 2013, 11:57 PM
timothy_nd28   SirAndy, you do so much for this site. I would be ...   Jul 3 2013, 12:11 AM
SirAndy   SirAndy, you do so much for this site. I would be ...   Jul 22 2013, 11:31 AM
Harpo   Kit and Labor (Members)............(Cylinders).......   Jul 22 2013, 06:51 PM
76-914   Thx Buddy, Al has got to be smiling. He loved doin...   Jul 3 2013, 08:21 AM
timothy_nd28   That or he's gonna come haunt me for giving up...   Jul 3 2013, 04:06 PM
boogie_man   Those look very, very good. Great workmanship :Q...   Jul 3 2013, 04:59 PM
timothy_nd28   Ok, I have been going over prices for this. As of...   Jul 3 2013, 11:05 PM
mrholland2   I'm in for this!!!!!!...   Jul 3 2013, 11:49 PM
914socal   I'm in for a kit and your labor service!   Jul 4 2013, 12:10 AM
monkeyboy   I'm in for an installed kit.   Jul 4 2013, 02:30 PM
Harpo   I'm in for the kit & your install services...   Jul 4 2013, 05:15 PM
Madswede   I'm in for a kit! This should work with my...   Jul 5 2013, 11:21 AM
timothy_nd28   Great! This circuit is very diverse as it was...   Jul 5 2013, 12:20 PM
Mr.242   The 'do it yourself' kit....are all the pi...   Jul 6 2013, 11:39 AM
timothy_nd28   It would be mighty cruel of me to give you a board...   Jul 6 2013, 03:37 PM
timothy_nd28   I should be clearer. If you want the kit and for m...   Jul 6 2013, 03:59 PM
poorsche914   Count me in for a kit. Does it include the LED str...   Jul 6 2013, 06:22 PM
timothy_nd28   Yep, the DIY kit will have enough led strip to do...   Jul 6 2013, 06:55 PM
timothy_nd28   Some progress today, the circuit boards have arriv...   Jul 17 2013, 11:46 AM
Mr.242   Do you have a time turn around on your work on a s...   Jul 17 2013, 11:55 AM
timothy_nd28   Turn around time will be one day. I'd hate to...   Jul 17 2013, 11:59 AM
lonewolfe   Put me down for one set including your labor. Can ...   Jul 17 2013, 02:00 PM
lonewolfe   Put me down for one set including your labor. Can...   Jul 17 2013, 02:02 PM
timothy_nd28   Put me down for one set including your labor. Ca...   Jul 17 2013, 02:29 PM
mepstein   Put me down for a kit. DIY, Let me know when you w...   Jul 17 2013, 06:44 PM
timothy_nd28   Got the prototype circuit board soldered up today....   Jul 19 2013, 09:34 PM
timothy_nd28   I have the redline red light to activate around 55...   Jul 19 2013, 09:58 PM
mrholland2   What's a good shift point? Mom's 64 Lemans...   Jul 19 2013, 10:57 PM
monkeyboy   I am usually getting ready to shift at 5,000. Then...   Jul 19 2013, 11:11 PM
timothy_nd28   Both lights are adjustable. I'll adjust the co...   Jul 19 2013, 11:12 PM
mepstein   Both lights are adjustable. I'll adjust the c...   Jul 20 2013, 03:42 AM
euro911   Wow, Tim ... I just saw this particular thread and...   Jul 20 2013, 05:19 AM
rick 918-S   Very cool   Jul 20 2013, 07:01 AM
eric9144   Can you do the small center console gauges as well...   Jul 20 2013, 08:57 AM
zambezi   This is going to be really cool. I will definitel...   Jul 20 2013, 10:02 AM
timothy_nd28   I haven't opened up the smaller console gauges...   Jul 20 2013, 10:03 AM
Harpo   This is very impressive. Looking forward to this ...   Jul 20 2013, 10:39 AM
mikeyb33   Amazing, fantastic work! Would be interested ...   Jul 20 2013, 11:07 AM
monkeyboy   Quick question about the gauge color change. Just ...   Jul 21 2013, 09:29 AM
timothy_nd28   Quick question about the gauge color change. Just...   Jul 21 2013, 03:28 PM
euro911   I want mine to come on when I get a bright idea   Jul 21 2013, 09:41 AM
monkeyboy   I want mine to come on when I get a bright idea ...   Jul 21 2013, 10:15 AM
euro911   I have plenty of burned out light bulbs here for y...   Jul 21 2013, 07:51 PM
timothy_nd28   Okay, I recorded some video last night. I'm a...   Jul 21 2013, 03:20 PM
Gary   Please put me down for a DIY. I'll need enough...   Jul 22 2013, 05:09 AM
timothy_nd28   Research and development phase is just about over....   Jul 22 2013, 11:24 AM
timothy_nd28   Right now I'm just doing the first 10 members ...   Jul 22 2013, 01:54 PM
mrholland2   Hi, I'm in the process of a major car project...   Jul 22 2013, 02:04 PM
SirAndy   [b]Kit and Labor(Members)............(Cylinders).....   Jul 22 2013, 02:28 PM
timothy_nd28   [b]Kit and Labor(Members)............(Cylinders)....   Jul 22 2013, 02:37 PM
SirAndy   Nice, I'll replace that plastic lens with some...   Jul 22 2013, 11:35 PM
SirAndy   Oh, one more thing, i have 5 gauges, not 3, since ...   Jul 22 2013, 11:37 PM
monkeyboy   I am in... How do we send you our gauges, and your...   Jul 22 2013, 02:07 PM
timothy_nd28   I am in... How do we send you our gauges, and you...   Jul 22 2013, 02:10 PM
eric9144   Can you change the speedo gearing to match a tire ...   Jul 22 2013, 03:59 PM
timothy_nd28   Can you change the speedo gearing to match a tire...   Jul 22 2013, 06:45 PM
ThePaintedMan   Sorry Tim, got your message but it got crazy at wo...   Jul 22 2013, 08:22 PM
timothy_nd28   I need two more volunteers for the kit+labor to co...   Jul 22 2013, 10:54 PM
Jakeodoule   I need two more volunteers for the kit+labor to c...   Jul 23 2013, 05:41 PM
timothy_nd28   Those are cool, just might keep them! I see n...   Jul 23 2013, 07:39 AM
timothy_nd28   Kit and Labor (*)= first 10 orders with price @ ...   Jul 23 2013, 05:52 PM
no1uno   I'd like to see the light. Include me for an ...   Jul 23 2013, 07:20 PM
timothy_nd28   I'd like to see the light. Include me for an...   Jul 24 2013, 12:03 AM
balljoint   :idea: The tach in my 914 has a little orange mar...   Jul 23 2013, 08:25 PM
timothy_nd28   If anyone can replicate this for me, I would so gi...   Jul 24 2013, 01:15 AM
euro911   If anyone can replicate this for me, I would so gi...   Jul 24 2013, 08:16 PM
timothy_nd28   Here's the remote that comes with the controll...   Jul 24 2013, 07:59 PM
timothy_nd28   :agree: Alrighty, I'm ready for the lucky fi...   Jul 24 2013, 08:52 PM
timothy_nd28   One last question for my first 10 group buyers. ...   Jul 24 2013, 10:35 PM
Jakeodoule   Mine is all stock. One last question for my firs...   Jul 25 2013, 01:12 PM
balljoint   My car is all stock.   Jul 25 2013, 08:16 AM
monkeyboy   I have an ignition system on my car, but I am runn...   Jul 25 2013, 10:31 AM
mrholland2   Stock   Jul 25 2013, 01:31 PM
rdauenhauer   Put me down for the full meal deal ...Kit and Labo...   Jul 25 2013, 01:59 PM
porkchopexpress   Outstanding work Tim! I am sure Al would be v...   Jul 28 2013, 11:58 AM
Mblizzard   At some point I am going to have to have this...   Jul 28 2013, 07:35 PM
- Lo-Fi Version Time is now: 28th October 2026 - 05:59 AM
