ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
I guess this one's probably best for Eric, but I'm curious what the consensus is on the topic, so feel free to chime in. If one were to install a different compound of pads on an existing rotor, is there anything that needs to be done so that they will bed correctly? The rotors are in good shape and in my opinion aren't in need of turning, but when you install a different compound of pad, isn't there a difference in the chemicals that are transferred to the rotor? Is there a way to clean a rotor so that any old residue is removed and the new pads will transfer that initial layer of chemical material to the rotors to allow them to be properly bedded?
I've seen some guys put better pads on at the track before a DE, but use the same rotors. Is this a no-no? |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Just follow the bedding procedure.
Lo-Fi Version | Time is now: 4th July 2025 - 07:29 PM |
