> New brake pads on used rotors, What is the procedure for bedding?
ThePaintedMan
post Jul 9 2013, 07:30 AM
I guess this one's probably best for Eric, but I'm curious what the consensus is on the topic, so feel free to chime in. If one were to install a different compound of pads on an existing rotor, is there anything that needs to be done so that they will bed correctly? The rotors are in good shape and in my opinion aren't in need of turning, but when you install a different compound of pad, isn't there a difference in the chemicals that are transferred to the rotor? Is there a way to clean a rotor so that any old residue is removed and the new pads will transfer that initial layer of chemical material to the rotors to allow them to be properly bedded?
I've seen some guys put better pads on at the track before a DE, but use the same rotors. Is this a no-no?
Cap'n Krusty
post Jul 9 2013, 11:44 AM
Cap'n Krusty
Back when these cars were manufactured, the rotors were hard and the pads soft. Now it's pretty much reversed. While the surfaces of the rotors may be a little work hardened, a simple bedding following the manufacturer's instructions should suffice. Agreed, the rotors should be flat and true for this to work.
The Cap'n
- Lo-Fi Version Time is now: 4th July 2025 - 09:11 PM
