| rhd914 |
Jul 9 2013, 11:06 PM
Newbie ![]() Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
Hi, well at long last my project car is almost complete. It came off the road in 2006 for a lot of reason. The car is now complete again and has a nice 3.2 in it along with a host of other upgrades.
I have just fitted Michelin pilot sport 3 front and rear. I want to send it for an alignment, but the spec for the rear toe in settings are in degree. Can anyone tell me what the setting is in millimeters? Thanks Geoff |
| stugray |
Jul 10 2013, 08:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE At the end of the day, you want almost just a hair of toe in at the rear. I assume you mean Toe IN ;-) As for the measurement it is: Wheel Diameter (mm)= WD Angle of Toe (degrees) = AT Distance of Toe = DT (mm) DT = WD * SIN(AT) So for a 15 inch rim (15 inches = 381mm) And One degree of Toe: DT = 381(mm) * SIN(1.0) = 381 * 0.01745 = 6.65 mm So for every degree of Toe-IN (near zero) you would space the forward rim of the wheel IN by ~6.6mm (or ~ 1/4 inch) Stu |
| r_towle |
Jul 10 2013, 11:35 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
rhd914 Rear toe settings Jul 9 2013, 11:06 PM
messix use this to convert, http://www.onlineconversion.c... Jul 9 2013, 11:15 PM
r_towle Tire diameter is required when using inches or MM ... Jul 10 2013, 08:25 AM
sixnotfour Factory setting is below, thanks to Bowlsby
15 mi... Jul 10 2013, 09:37 AM
SirAndy Can anyone tell me what the setting is in millime... Jul 10 2013, 11:10 AM
r_towle
Can anyone tell me what the setting is in millim... Jul 10 2013, 11:39 AM
Dave_Darling
To much toe IN at the rear makes the car really d... Jul 10 2013, 06:01 PM
r_towle
To much toe IN at the rear makes the car really ... Jul 10 2013, 07:27 PM
Bartlett 914
If you are using strings to align the car and m... Jul 10 2013, 04:19 PM
stugray
Sorry, when I read that my brain registered:
... Jul 10 2013, 11:45 AM
Travis Neff toe in makes the car more stable in a straight lin... Jul 10 2013, 12:12 PM
Downunderman Geoff, I run about 1 - 1.5 mm per side toe in on t... Jul 10 2013, 01:03 PM
jimkelly I assume you guys do this with car on ground with ... Jul 10 2013, 01:19 PM
sixnotfour
measured where ?? Jul 10 2013, 06:39 PM
Dave_Darling Read it again, Rich.
Toe OUT in front, better tur... Jul 10 2013, 10:42 PM
rhd914 Hi and thanks for the reply's. I was looking f... Jul 11 2013, 01:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:21 AM |
