> CV joint repack/boots *trouble**, C-clip or no?
nine9three
post Jul 11 2013, 12:26 AM
In the process of cleaning and repacking the cv joints. Everything went together well but when it comes to replacing the (IMG:style_emoticons/default/headbang.gif) retaining clip on the axle, I can't get the joint far enough on the axle to reinstall the thick retaining ring. So, do I replace with a conventional clip (with plier holes/thiner) or leave the joint to "float" without clips??
ThePaintedMan
post Jul 11 2013, 07:35 AM
The way I've done it is to hammer the clip against the joint itself, pushing the assembly back until the clip engages the slot. Just use an appropriately sized socket.
nine9three
post Jul 11 2013, 03:36 PM
QUOTE(ThePaintedMan @ Jul 11 2013, 06:35 AM) *
The clip was a little wide after removal so I carefully tapped the sides to bring it back together and placed it on the axle. I then used a 1" socket over the axle end and tapped it together. The clip went right into place. Thanks for the hint. I spent an hour last night trying to get the clip on. (IMG:style_emoticons/default/wacko.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 12:53 PM
