Seized No one main bearing, But also found this |
jeffdon |
Jul 14 2013, 12:12 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
r_towle |
Jul 14 2013, 06:56 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
After seeing both, if this is the same motor with the seized main bearing...
You need to look at your oiling system...slumping ain't right. |
jeffdon |
Jul 14 2013, 07:17 PM
After seeing both, if this is the same motor with the seized main bearing... You need to look at your oiling system...slumping ain't right. Well, it was a cold start after not running for over 6 months. I did NOT pull the plugs and spin it to build pressure. Wish I would have. And I just had a thought. When installing the pump the FIRST (well, actually second, due to having to tear it down to get out a dropped washer), I snapped the end of the cam off with the oil pump 180 out of orientation. Replaced the cam. Think I bent the gear? |
OCD Performance |
Jul 14 2013, 08:16 PM
Newbie Group: Members Posts: 10 Joined: 10-July 13 From: Canada Member No.: 16,112 Region Association: None |
After seeing both, if this is the same motor with the seized main bearing... You need to look at your oiling system...slumping ain't right. Well, it was a cold start after not running for over 6 months. I did NOT pull the plugs and spin it to build pressure. Wish I would have. And I just had a thought. When installing the pump the FIRST (well, actually second, due to having to tear it down to get out a dropped washer), I snapped the end of the cam off with the oil pump 180 out of orientation. Replaced the cam. Think I bent the gear? Wow. (IMG:style_emoticons/default/headbang.gif) Bingo. Yes, get another case and gear set. Did the crank survive? If it really did, flush the hell out of the oil drillings. |
jeffdon |
Jul 14 2013, 08:22 PM
After seeing both, if this is the same motor with the seized main bearing... You need to look at your oiling system...slumping ain't right. Well, it was a cold start after not running for over 6 months. I did NOT pull the plugs and spin it to build pressure. Wish I would have. And I just had a thought. When installing the pump the FIRST (well, actually second, due to having to tear it down to get out a dropped washer), I snapped the end of the cam off with the oil pump 180 out of orientation. Replaced the cam. Think I bent the gear? Wow. (IMG:style_emoticons/default/headbang.gif) Bingo. Yes, get another case and gear set. Did the crank survive? If it really did, flush the hell out of the oil drillings. A whole new case? Oh god, I need a drink. (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:27 PM |
