Seized No one main bearing, But also found this |
jeffdon |
Jul 14 2013, 12:12 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
McMark |
Jul 16 2013, 03:12 PM
Your pump and your cam gear need modification/clearancing. Your case is not ruined.
r_towle |
Jul 16 2013, 03:29 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Your pump and your cam gear need modification/clearancing. Your case is not ruined. in looking at both your cam thrust bearing and your main crank bearings, I would not assume the case is not harmed. See if you can take some pictures of the ends of the case at the bearing locations for both ends of the crank and camshaft. Also, the bearing saddles. rich |
Lo-Fi Version | Time is now: 1st June 2024 - 11:15 AM |
