| David Stowers |
Jul 16 2013, 12:14 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
One of my lights doesn't come up. You can wind it up but if you go all the way up it then puts itself away again. If you wind it most of the way up it will go away if you switch them off. I've swapped the relays over and it makes no difference.
I'm rubbish with electrics so be gentle with me! Any suggestions? Thanks |
| 7TPorsh |
Jul 16 2013, 02:48 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
Is the driver's side normal?
| Eric_Shea |
Jul 16 2013, 05:18 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Is the driver's side normal? He's in the UK... (IMG:style_emoticons/default/biggrin.gif) Round relay under the cover. Four Philips screws and swap the relay with the other side. Fix it? |
| 76-914 |
Jul 16 2013, 05:30 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Is the driver's side normal? He's in the UK... (IMG:style_emoticons/default/biggrin.gif) Round relay under the cover. Four Philips screws and swap the relay with the other side. Fix it? (IMG:style_emoticons/default/poke.gif) Erc, are you hitting the coffee again? Re-read first post. (IMG:style_emoticons/default/slap.gif) |
David Stowers Headlight won't pop up Jul 16 2013, 12:14 PM
7TPorsh start by checking around the lights for loose brow... Jul 16 2013, 12:21 PM
David Stowers
start by checking around the lights for loose bro... Jul 16 2013, 12:24 PM
sfrenck
start by checking around the lights for loose bro... Jul 24 2013, 04:50 AM
ripper911 Mine did that for a while. I think I just jiggled... Jul 16 2013, 02:51 PM
Drums66
Mine did that for a while. I think I just jiggle... Jul 16 2013, 06:53 PM
David Stowers Drivers side is normal, I think I'll have to g... Jul 16 2013, 03:03 PM
euro911 Has it always done this, or just recently?
Mine w... Jul 16 2013, 03:32 PM
David Stowers I've not had it on the road yet since getting ... Jul 16 2013, 03:38 PM
mrholland2 For headlights that won't "pop up", ... Jul 16 2013, 03:42 PM
David Stowers
For headlights that won't "pop up",... Jul 16 2013, 03:46 PM
mrholland2
For headlights that won't "pop up... Jul 17 2013, 01:35 PM
David Stowers
[quote name='David Stowers' post='1895982' date='... Jul 17 2013, 03:48 PM
Eric_Shea Oh.... :blink:
("read" being the operat... Jul 16 2013, 05:37 PM
jeeperjohn56 Had the same problem ended being a bad wire connec... Jul 17 2013, 01:29 PM
euro911
I was joking with my cardiologist, told him I wa... Jul 17 2013, 09:00 PM
7TPorsh Alice doesn't live here anymore... Jul 18 2013, 11:59 AM
David Stowers
Alice, ... Jul 24 2013, 03:54 AM
ripper911 Of course if you need to use your headlights befor... Jul 24 2013, 05:30 AM
David Stowers
Of course if you need to use your headlights befo... Aug 13 2013, 07:02 AM
David Stowers Any ideas? Anyone? Pleeeeeaase!!! Aug 14 2013, 02:10 AM
David Stowers :bump: Aug 15 2013, 03:18 AM
euro911 David, do you have an electrical wiring diagram? W... Aug 15 2013, 09:04 AM
David Stowers
David, do you have an electrical wiring diagram? ... Aug 15 2013, 12:13 PM
r_towle hold up.
Get some jumpers and unplug the motor an... Aug 15 2013, 04:29 PM
HalfMoon
One of my lights doesn't come up. You can win... Aug 15 2013, 06:04 PM
Porsche930dude probrobly the connections. those motors are stout... Aug 15 2013, 06:30 PM
mepstein the motors rarely go bad. that's why they are ... Aug 15 2013, 09:07 PM
David Stowers Thanks guys, the motor works as it will still clos... Aug 16 2013, 02:00 AM
David Stowers Thanks guys, the motor works as it will still clos... Aug 16 2013, 10:57 AM
r_towle It's a home run circuit for each headlight all... Aug 16 2013, 04:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 02:22 PM |
