tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I was driving along today (about 40mph) and I looked in the rear view mirror and saw smoke. I immediately looked at the oil pressure gauge and right when I looked down, I saw the oil pressure gauge go to 0. It was not safe for me to turn off the engine and stop, I drove it at low rpm for about 1 minute until I could get in safe area. Everything was running fine when I shut down the engine. The head temps were normal. I have not started the engine since.
It turns out that one of the lines for my external oil cooler tore. I was able to get the car home on a friends trailer. I had fresh oil in the engine when the line tore. What are the chances that I majorly screwed up my engine? How can I find out if I did? |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
QUOTE Soooo....how long can an engine run at 0 oil pressure... Until it seizes... (IMG:style_emoticons/default/sad.gif) I had a similar occasion with my rotary. Tore off the oil drain plug after hitting a bump on the highway. Shut the motor down but had to restart to get it safely off the road. Engine was fine after repair and refilling. Both the T4 and Rotary rely heavily on oil for lube and cooling. Hopefully yours is OK. |
Lo-Fi Version | Time is now: 11th July 2025 - 11:35 AM |
