| ThePaintedMan |
Jul 17 2013, 07:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Well now that I know I can replace the stud at the back of this spare transmission, I set out to replace all the seals in it. Started with the hardest one - the input shaft seal. I've done one before successfully, but this one is a beehotch. I used a double hooked seal puller but only managed to rip through the metal 3/4 the way around the seal and it's currently still in there.
I have a PM out to the good Dr. for his ideas, but wondering if anyone else has any tips? I have a slide hammer somewhere, but not sure if I have the necessary attachment to adapt it to pull a machine screw if I drill through the seal. Not sure I really like the idea of drilling in that area anyway. Can the race surrounding the seal be heated with propane? I've heard it mentioned that at least some 901 boxes were magnesium and in that case, it's a definite no-no. The other though I had would be to take it to a nearby machine shop and see if they can pull it. I guess otherwise I have to pull the gear stack and drive it out from the inside? |
| Dave_Darling |
Jul 18 2013, 11:41 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Can you pull off the side cover and push the seal out from inside the transmission?
I've also heard of people CAREFULLY running a screw into the seal, and then using that to pull the seal out. --DD |
| nine9three |
Jul 18 2013, 10:12 PM
Member ![]() ![]() Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest |
Can you pull off the side cover and push the seal out from inside the transmission? I've also heard of people CAREFULLY running a screw into the seal, and then using that to pull the seal out. --DD (IMG:style_emoticons/default/agree.gif) I just performed this procedure on my transmission. Pull the side cover and with a long drift, pop the old seal out. Simple. Just remember to replace the large o-ring seal on the side cover. It is a good time to inspect at least one of the carrier bearings. |
ThePaintedMan - SOLVED - More dumb transmission stuff Jul 17 2013, 07:39 PM
Mblizzard George is this the one that is covered by a small ... Jul 17 2013, 09:15 PM
ThePaintedMan
George is this the one that is covered by a small... Jul 18 2013, 06:28 AM
Mblizzard
George is this the one that is covered by a smal... Jul 18 2013, 02:52 PM
ThePaintedMan
Can you pull off the side cover and push the seal... Jul 18 2013, 01:49 PM
worn
Well now that I know I can replace the stud at th... Jul 18 2013, 03:33 PM
ThePaintedMan I remembered how I ended up having to get the firs... Jul 18 2013, 08:26 PM
euro911 Maybe Evil can comment on this?
I know an old sch... Jul 18 2013, 11:19 PM
ThePaintedMan Well good to know it can be accessed through the s... Jul 19 2013, 07:05 AM
euro911 What happens when the little retainer spring even... Jul 19 2013, 11:08 AM
76-914 the spring is trash, throw it away. it won't b... Jul 19 2013, 08:10 AM
ThePaintedMan
the spring is trash, throw it away. it won't ... Jul 19 2013, 08:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:14 PM |
