| ThePaintedMan |
Jul 17 2013, 07:39 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Well now that I know I can replace the stud at the back of this spare transmission, I set out to replace all the seals in it. Started with the hardest one - the input shaft seal. I've done one before successfully, but this one is a beehotch. I used a double hooked seal puller but only managed to rip through the metal 3/4 the way around the seal and it's currently still in there.
I have a PM out to the good Dr. for his ideas, but wondering if anyone else has any tips? I have a slide hammer somewhere, but not sure if I have the necessary attachment to adapt it to pull a machine screw if I drill through the seal. Not sure I really like the idea of drilling in that area anyway. Can the race surrounding the seal be heated with propane? I've heard it mentioned that at least some 901 boxes were magnesium and in that case, it's a definite no-no. The other though I had would be to take it to a nearby machine shop and see if they can pull it. I guess otherwise I have to pull the gear stack and drive it out from the inside? |
| ThePaintedMan |
Jul 19 2013, 07:05 AM
Well good to know it can be accessed through the side cover. I have an entire new gasket set, so I probably should have gone that route. Did not know if there was enough clearance to pop it out from the back with the guts still in the transmission. Thanks for the heads up! Maybe I'll pull the cover off just for the sake of learning something new.
Mark, that's an interesting approach too. Though I'm not sure I'd want to have that spinning around inside on the input shaft on it's own accord. What happens when the little retainer spring eventually pops off the rubber? |
ThePaintedMan - SOLVED - More dumb transmission stuff Jul 17 2013, 07:39 PM
Mblizzard George is this the one that is covered by a small ... Jul 17 2013, 09:15 PM
ThePaintedMan
George is this the one that is covered by a small... Jul 18 2013, 06:28 AM
Mblizzard
George is this the one that is covered by a smal... Jul 18 2013, 02:52 PM
Dave_Darling Can you pull off the side cover and push the seal ... Jul 18 2013, 11:41 AM
ThePaintedMan
Can you pull off the side cover and push the seal... Jul 18 2013, 01:49 PM
nine9three
Can you pull off the side cover and push the seal... Jul 18 2013, 10:12 PM
worn
Well now that I know I can replace the stud at th... Jul 18 2013, 03:33 PM
ThePaintedMan I remembered how I ended up having to get the firs... Jul 18 2013, 08:26 PM
euro911 Maybe Evil can comment on this?
I know an old sch... Jul 18 2013, 11:19 PM
euro911 What happens when the little retainer spring even... Jul 19 2013, 11:08 AM
76-914 the spring is trash, throw it away. it won't b... Jul 19 2013, 08:10 AM
ThePaintedMan
the spring is trash, throw it away. it won't ... Jul 19 2013, 08:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:14 PM |
