Intake hose/gasket replacement |
jdogg |
Apr 25 2003, 11:04 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Any one got an easy way to do this?('72 2.0) Just took a quick look tonight, looks like engine tin will have to be removed. I just want to replace the intake hoses. Any suggestions for simplicity's sake? Brad? You're always good for a step by step for newbies!! (IMG:style_emoticons/default/beer.gif)
Brad Roberts |
Apr 26 2003, 10:43 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Intake plenum is cracked or the throttle bdy shaft is worn out.
While the car is running.. shoot WD40/brake cleaner/something.. around the raised portion of the plenum that the throttle body sits on. They tend to crack underneath and cause lean problems (and you can't see it). If the idle doesnt change or the car doesnt die... shoot some of the WD/CARB/Brake stuff around the throttle shaft. Just too eleminate the AAR.. plug the hose. The 2 things I listed above should only take about 15 minutes to check. Leave the air cleaner off... I'm surprised more people dont chat about broken 2.0 plenums on these lists.. we run across ones that need to be brazed at least 3 times a month. People dont adjust the throttle stop correctly at the pedal board or they dont have a pedal board and the cable yanks on the throttle body causing the plenum to stress crack. B |
Lo-Fi Version | Time is now: 7th June 2024 - 07:17 PM |
