Seized No one main bearing, But also found this |
jeffdon |
Jul 14 2013, 12:12 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
r_towle |
Jul 15 2013, 01:36 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
take a picture of the end of the camshaft...the bolt heads.
and a picture of the back of the oil pump . please rich |
jeffdon |
Jul 15 2013, 01:48 PM
76-914 |
Jul 24 2013, 03:57 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
take a picture of the end of the camshaft...the bolt heads. and a picture of the back of the oil pump . please rich Slightly shows on the bolts, the pump took the worst of it. Hell, that's just a scratch! The PO of this engine was very determined that it would run. (IMG:style_emoticons/default/av-943.gif) Are you having a machinist check your case before you start throwing parts at her? |
Cap'n Krusty |
Jul 24 2013, 05:06 PM
take a picture of the end of the camshaft...the bolt heads. and a picture of the back of the oil pump . please rich Slightly shows on the bolts, the pump took the worst of it. Hell, that's just a scratch! The PO of this engine was very determined that it would run. (IMG:style_emoticons/default/av-943.gif) Are you having a machinist check your case before you start throwing parts at her? Let me be the first to suggest using JB Weld here ........................ The Cap'n |
r_towle |
Jul 25 2013, 07:14 PM
take a picture of the end of the camshaft...the bolt heads. and a picture of the back of the oil pump . please rich Slightly shows on the bolts, the pump took the worst of it. Hell, that's just a scratch! The PO of this engine was very determined that it would run. (IMG:style_emoticons/default/av-943.gif) Are you having a machinist check your case before you start throwing parts at her? Let me be the first to suggest using JB Weld here ........................ The Cap'n (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:45 AM |
