restoration 914 |
restoration 914 |
porschematt |
Jul 26 2013, 06:55 PM
Newbie Group: Members Posts: 12 Joined: 25-July 13 From: winder ga Member No.: 16,161 Region Association: None |
Starting my restoration on my 914 im 18 and need a little help if anyone has any advice plz reply thabks
Attached thumbnail(s) |
jimkelly |
Jul 27 2013, 05:43 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
because you can pull the motor/trans at any time.
I would say use what you got in regards to motor and trans. you can always install a different motor and trans at a later date. i'd say, get body, suspension, brakes, fuel system, done first. do a compression test on your engine to see what each cylinder has for psi. i'd even say run it with a single carb initially if that is what you have. so you can put your money elsewhere for now. that said, it seems a nice set of dual dellortos/webers run about $400 typically. you won't need the biggest out there. http://www.914world.com/bbs2/index.php?sho...p;hl=dual+carbs |
Lo-Fi Version | Time is now: 1st June 2024 - 09:02 AM |
