LSD Setup Thoughts for Leeloo, Figuring out the choices |
nine14cats |
Jul 28 2013, 04:02 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Hey Guys,
I need some advice for Doris' car on Limited Slips. We are putting the car down for the winter as it is getting some mods done over the next couple of months and I need to dismantle some of the car. Mods are: 1. Going to TCDesign in Sept/Oct for new cage with door bars for safety. The bolt in cage has the door bars too low to help with a collision. At the same time I will have Tony tie in the shock towers front and rear and add chassis stiffening. The cage will also be NASA/PCA Racing legal without using a Petty bar, which makes it more comfortable inside the car. 2. Roger Sheridan is making me up his lightweight front and rear lids along with a new targa top that will allow more room for Tony's cage. At this point I plan on going back in with the dash, door panels, and some carpeting to make the car more "stealth". 3. I have ordered 21mm hollow T-bars for the car and I have plenty of springs in the garage to try. I may bump the spring rate in back up a tad to 275lbs/300lbs from the current 250lbs to help with turning and then with the softer front end I can get some Anti Roll bar adjustability back as I have the front bar full soft and it still pushes. The car is way too stiff in front. 4. We are going to bias ply slicks for the setup. We will use R35 / R45 compound Hoosiers for AX/track and eventually move to Avons for AX. I'll also redo shock valving after I figure out the T-bar/rear spring rates. At that time I will have the spindles raised. That brings me to a limited slip/trans combo. Doris hates the 901 and remembers the 915 we had in our 930 (I had swapped the 930 4 speed for a 915 5 speed which was much nicer to drive around town). She liked that trans. I have a 915 box and will spring for a WEVO kit and flipping the R&P. So now I need to decide on a limited slip. The hot AX ticket is a Torsen style but it offers no help under braking on the track. I really liked the feel of our ZF style Guard on our previous 914-6 as you can feel it settle the rear end under braking in high speed situations. It made the car easier to drive. Since Doris will be driving the heck out of the car at DE's, I'm thinking a 40/60 clutch style from Guard. 40% lock up under power and 60% lock up under braking. That should tame the car in braking Thill or BW and still make the car hookup out of slow corners. What do you guys think? I'm trying to setup the car for her to enjoy and not make it a stiff race car like I would drive. Thanks, Bill P. |
J P Stein |
Jul 29 2013, 06:29 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Bill:
You've reached a Y in the road for building an AX vs track car. |
nine14cats |
Jul 29 2013, 07:46 AM
Bill: You've reached a Y in the road for building an AX vs track car. Hi JP, I would say it's more of a W then a Y and back to a W!.... (IMG:style_emoticons/default/blink.gif) Actually, the only difference in the hard parts is the diff. The car will be set softer with an AX bias, but I won't be cutting off the windshield, but may go Lexan. I also have to take in the main driver's inputs as they are important. I'm getting quotes today on the 915 trans build with both the Guard and the Wavetrac unit in it. Bill P. |
Randal |
Jul 29 2013, 07:55 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Bill: You've reached a Y in the road for building an AX vs track car. Hi JP, I would say it's more of a W then a Y and back to a W!.... (IMG:style_emoticons/default/blink.gif) Actually, the only difference in the hard parts is the diff. The car will be set softer with an AX bias, but I won't be cutting off the windshield, but may go Lexan. I also have to take in the main driver's inputs as they are important. I'm getting quotes today on the 915 trans build with both the Guard and the Wavetrac unit in it. Bill P. So what is the party line on why TB diffs are not good on the track? Mine works everywhere I've driven it, in fact, it's works so good that you wouldn't even know it's there. The car just handles. Need some enlightenment. |
Lo-Fi Version | Time is now: 6th June 2024 - 03:33 AM |
