| CG-914 |
Jul 30 2013, 10:51 PM
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
I have a 74 2.0 with the blue bosch coil
I wanna test my coil. What are the ohm numbers I need to see between which points? Wich wire is ground? Is the other getting 12V? Side question: Whats the threat on the oil drain plug? |
| TheCabinetmaker |
Jul 31 2013, 12:55 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
No threat on the drain plug. New cruch washer and proper torque. However, The strainer cover is a different story. Its only torques to 8 ft lbs. The pick up for the oil is held in place by one of the engine case bolts. Too much torque on the strainer nut can pull the bolt and crack the case rendering it useless.
CG-914 Ignition Coil Jul 30 2013, 10:51 PM
McMark The only real test is to bolt on a new one and see... Jul 31 2013, 12:16 PM
nathansnathan Ratwell gives some info on blue coils on his bus p... Jul 31 2013, 04:49 PM
CG-914 Thank you for the help.
I was asking about the th... Aug 1 2013, 11:48 PM
Elliot Cannon
I was asking about the t... Aug 1 2013, 11:59 PM
bulitt Pull the wire going from the coil to the distribut... Aug 2 2013, 05:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:14 PM |
