914-6 air conditioning, Advice on compressor choise |
turboman |
Jul 3 2012, 07:56 AM
Newbie Group: Members Posts: 6 Joined: 22-June 12 From: Montoison France Member No.: 14,589 Region Association: France |
Hi, I am in the process to install an original 914 VPC system in my 914-6.
Like all my projects, I work on a budget. First I bought all the parts about 5 years ago, then I refurbished all parts, (professional cleaning, expansion valve) installed the condenser in the front trunk as designed, temporary installed the evaporator console under the dash, and start the preparation process for the compressor installation. I want the installation to be as close as possible to a factory one. For me, is not an option a compressor under the engine, a serpentine belt or similar. I prefer to work extra time, and reach a perfect end product. I used a double pulley from a 74 911, in order to install the pulley and have space for the dual belts, I have to shave a bit the original engine support and the engine cover (see photo). I fit a 2.2 or 2.4 bracket. So far no problems, the end result looks very nice Now I need to choose the compressor. The York is out of question, due to size and efficiency. My options are a Sanden, a Denso or a Panasonic. Any one fitted with a one groove pulley Not being familiar with the air conditioner compressors, and the way you need to calculate cooling capacity vs cabin volume, I would like to ask help form all of you. 1. Which compressor will suit my needs the best? 2. Which compressor is the smallest one? 3. The best compromise? I will keep all of you posted of the progress on the installation and the need or not of a firewall modification. Thanks Francisco Attached thumbnail(s) Attached image(s) |
Al Meredith |
Jul 3 2012, 09:57 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
George Hussey at Auto Atlanta has Peter Greg's 916 that I think has factory installed AC . The pulley of the AC compressor must go through the firewall. On George's car there is a hump in the firewall behind the drivers seat.
mepstein |
Jul 3 2012, 10:11 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
George Hussey at Auto Atlanta has Peter Greg's 916 that I think has factory installed AC . The pulley of the AC compressor must go through the firewall. On George's car there is a hump in the firewall behind the drivers seat. I'm pretty sure George's 916 has a crude, covered up hole in the firewall. I also remember reading it was not factory installed but added on when the car was brought over from Germany. There is no "factory" installed a/c in a 914-6 and so far, very limited success with aftermarket installs. The factory a/c mount on the six causes the compressor to hit the firewall. I wonder if an electric compressor might work. Like something used on an electric car. |
racerbvd |
Aug 1 2013, 08:23 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
George Hussey at Auto Atlanta has Peter Greg's 916 that I think has factory installed AC . The pulley of the AC compressor must go through the firewall. On George's car there is a hump in the firewall behind the drivers seat. I'm pretty sure George's 916 has a crude, covered up hole in the firewall. I also remember reading it was not factory installed but added on when the car was brought over from Germany. There is no "factory" installed a/c in a 914-6 and so far, very limited success with aftermarket installs. The factory a/c mount on the six causes the compressor to hit the firewall. I wonder if an electric compressor might work. Like something used on an electric car. Correct, Brumos installed it, Phil happened to be at the dealership the day they were cutting the 916 (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 06:26 PM |
