Gauge blinker question |
rob gannon |
Aug 3 2013, 09:27 AM
Newbie Group: Members Posts: 22 Joined: 31-July 11 From: b'ham alabama Member No.: 13,380 Region Association: South East States |
Hi, I have a 1970, the gauges are in terrible condition. I have a 1974 set of gauges that are much nicer I am going to replace them with. The early set has individual left and right blinker bulbs located on the tach gauge. The later tach gauge has one bulb shared by both sides. My question is: is it ok to jumper the wires from the left and right blinker to the single bulb in the newer gauge? I just don't want to do any damage.
Thanks, rob |
rob gannon |
Aug 3 2013, 05:39 PM
As far as using newer gauges - I was trying to use stuff on hand and be cheap. However I do like the look of the older gauges better. This leads to a part two question. With my older two bulb setup sometimes when I would turn on either left or right blinker, sometimes both sides would blink. Sometimes the correct side would blink and after a few seconds then both sides would start blinking- only on the dash, on the outside lights it was correct. Is that a ground issue? I've checked all the grounds I can find. Is there one I may be missing?
Lo-Fi Version | Time is now: 2nd June 2024 - 09:00 AM |
