912E/923 Transmission, I need some insight.... |
Britain Smith |
Jul 15 2004, 12:09 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Can anyone provide me with some random bits of information about the 912E transmission?
As you all know, am building a fairly powerful type-4 engine and I was headed down the path of mating it to a 915 transmission. I could either (A) use a conversion flywheel from Kennedy and machine it to match my dowel-pinned crank, or ((IMG:style_emoticons/default/cool.gif) use a 923 transmission from a 912E which has a type-4 mainshaft and would allow me to keep the dowel-pined, lightened flywheel that I already have. I know that the 923 tranny is a mag case with a 7:31 R&P which has it's own set of issues, but I need some additional information to sway me either way. I am also interested in some further explaination of the gearing. The 912E gearset looks like the following: 1976 (5-Spd) 11:35 11:33 23:29 26:25 29:21 7:31 Is there any reason why the first and second gears are so close in ratio to each other? I plugged this into my calculator and found that the 1-2 shift is ridiculously short...this can't be right. The 72-73 & 74 915's gearing looks like this: 1972-73 915 11:35 18:33 23:29 26:25 29:22 7:31 (5-Speed) 1974 915/06 11:35 18:33 23:29 27:25 29:21 7:31 (5-Speed) Do you think that a type-4 motor would be better off with the 912E gearing or the normal 915? Anyone? Jake...I know you have done a fair bit or research into this, any thoughts? -Britain |
bondo |
Jul 15 2004, 12:25 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Hmm, I don't see how it's possible to have an 11:33 and an 11:35 in the same transmission. Are you sure your data is accurate? An18:33 tooth count like the others seems more likely.
Lo-Fi Version | Time is now: 9th June 2024 - 09:27 PM |
