912E/923 Transmission, I need some insight.... |
Britain Smith |
Jul 15 2004, 12:09 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Can anyone provide me with some random bits of information about the 912E transmission?
As you all know, am building a fairly powerful type-4 engine and I was headed down the path of mating it to a 915 transmission. I could either (A) use a conversion flywheel from Kennedy and machine it to match my dowel-pinned crank, or ((IMG:style_emoticons/default/cool.gif) use a 923 transmission from a 912E which has a type-4 mainshaft and would allow me to keep the dowel-pined, lightened flywheel that I already have. I know that the 923 tranny is a mag case with a 7:31 R&P which has it's own set of issues, but I need some additional information to sway me either way. I am also interested in some further explaination of the gearing. The 912E gearset looks like the following: 1976 (5-Spd) 11:35 11:33 23:29 26:25 29:21 7:31 Is there any reason why the first and second gears are so close in ratio to each other? I plugged this into my calculator and found that the 1-2 shift is ridiculously short...this can't be right. The 72-73 & 74 915's gearing looks like this: 1972-73 915 11:35 18:33 23:29 26:25 29:22 7:31 (5-Speed) 1974 915/06 11:35 18:33 23:29 27:25 29:21 7:31 (5-Speed) Do you think that a type-4 motor would be better off with the 912E gearing or the normal 915? Anyone? Jake...I know you have done a fair bit or research into this, any thoughts? -Britain |
ArtechnikA |
Jul 15 2004, 02:49 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(Eric_Shea @ Jul 15 2004, 12:41 PM) I want that TL 923.302.905.53 however - it shows NLA at Stoddard ... |
Lo-Fi Version | Time is now: 9th June 2024 - 08:39 PM |
